Lug nuts
Old Oct 21, 2004 | 08:40 PM
Z0SLIK's Avatar
Z0SLIK
Default Lug nuts
Going to raise the car this weekend for the first time. Time for a wheel and well cleaning. Is there a site that can give me a step by step instructions or anyone that can give advise? I have all the equipment with the exception of the torque wrench. I understand that it is 19mm. Is there one that will not scatch chrome lugs? Where is the best place to get one? Hockey pucks or lift pads? Suggestions? Any help and pointers will be greatly appreciated.
Old Oct 21, 2004 | 09:19 PM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
Cruise-In 8-9-10-11 Veteran
CI 9, 10 & 11 Car Show Winner
St. Jude Donor '08-'10
unless you have aftermarket lugs, you wont scratch the lugs, or at least i didnt with a normal deep socket.
i have the pucks and i just took the seat part off my jack so it would hit the puck flush and took it up easy.
Old Oct 21, 2004 | 09:31 PM
Davesredvette's Avatar
Davesredvette
The stock lugs have plastic caps that unscrew by hand with a scocket. The actual lugs are just regular acorn nuts that are ugly and it doesn't really matter if they get scratched since they are totally covered....
For the rear I use a floor jack with a piece of plywood and lift the entire rear of the car under the diff. For the front I lift each side individually by jacking up the spring close to the wheel.
The torque spec for the lugs when tightening is 100 ft lbs.....
It's a great time to lower when all the wheels are off....
Good luck,
Dave
Old Oct 21, 2004 | 10:01 PM
T's's Avatar
T's
Cruise-In VII Veteran
St. Jude Donor '06-'07-'08
Here ya go slick
Old Oct 21, 2004 | 10:03 PM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
newer vettes have regular lugs, not the plastic capped ones.
Old Oct 21, 2004 | 10:07 PM
Z0SLIK's Avatar
Z0SLIK
T, When I get the wheels off let's lower that sucker.
Old Oct 21, 2004 | 10:17 PM
T's's Avatar
T's
Ghost/wrench is ready
To Lug nuts
