From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
When you make your post or reply to a thread - isn't there a group of "smilies" in a box right next to the text box? If not - look below the text box, and see if you have Disable Smilies in Text checked. If so - uncheck it.
To insert a smilie, place your cursor where you want the smilie to appear, and click on the one of your choice. The full list of available smilies will appear if you double click on the More at the lower left hand corner of the smilie box in a separate window. The process is the same - cursor and click on your choice. Hope this helps and BTW - IB4TL!
Thanks for the info. As usual, I was overanalyzing the process.
Good to go now.
