Headlight question?
Old Oct 23, 2004 | 01:01 PM
Blowtorch's Avatar
Blowtorch
Default Headlight question?
OK...here I am ready to install my Silverstars and I find the headlight has 2 bulbs. The literature with the Silverstars says this halogen upgrade replaces both low and high beam. So......which bulb do I take out? Both? and only put one back in? Or do i need 4 Silverstars??????
HELP!.......
Old Oct 23, 2004 | 01:10 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
According to the Silverstar web site, you need four bulbs (2 low, 2 high)
9005 & 9006 are the high and low beam bulbs respectively.
However, they're listing a 9004 with 50/70 watts and a 9007 with 60/70 watts as well. If you have one of those, I have NO idea what the hell you're supposed to do.
Old Oct 23, 2004 | 01:48 PM
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
You need four, as stated above.
Old Oct 23, 2004 | 01:55 PM
BeastieBoys21's Avatar
BeastieBoys21
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Please post how much of an improvement they are include some pics if you can.
Old Oct 23, 2004 | 01:59 PM
BQuicksilver
Better, but barely worth the cost. I tried at one point.
Old Oct 23, 2004 | 02:31 PM
Blowtorch's Avatar
Blowtorch
They are in!
It is true, you need 4 bulbs. I was confused by all the posts about spending only $38. I guess most people don't bother to do the high beams. I went back and got the other set for the high beams.
The trickiest part is getting the socket back into the hole! It's another small hands job.
I will be using the car this evening so I will file a report tomorrow.
Old Oct 23, 2004 | 03:59 PM
JackTsDBG's Avatar
JackTsDBG
Did it myself, slightly better whiter light. Fortunately I got a great deal on a set of 4 Silverstars, otherwise I would have been really unhappy. The stock lights just suck.
Old Oct 23, 2004 | 04:02 PM
JackTsDBG's Avatar
JackTsDBG
Did all four also, slightly better whiter light. Fortunately I got a great deal on the Silverstars, otherwise I would have been really unhappy. The stock lights just suck, no matter what's in them.
To Headlight question?
