Double Nickle--5th or 6th gear
Old Oct 24, 2004 | 10:00 AM
TkitPlz's Avatar
TkitPlz
Default Double Nickle--5th or 6th gear
For those of you that do go 55-60 once in awhile and own a 6 sp., do you ever run at that speed in 6th gear or is is not advisable. I know 6th at that speed runs the engine at about 150 rpm. Just wondering if I should keep it in 5th at that speed or move it to 6th. I know...I know... Dan
Old Oct 24, 2004 | 10:02 AM
TkitPlz's Avatar
TkitPlz
Default I MEANT 1500 rpm
Sorry, I said 150 and meant 1500
Old Oct 24, 2004 | 10:04 AM
mowton's Avatar
mowton
5th for cruising and even 4th if "quick changes" are required
Old Oct 24, 2004 | 10:16 AM
BeastieBoys21's Avatar
BeastieBoys21
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
4th usually, but if im just crusing along ill go into 5th. My usual crusing speed is 70-75 HA
Old Oct 24, 2004 | 10:24 AM
14U2ENV's Avatar
14U2ENV
From: Lino Lakes, MN _________________________ I Figured out how to do this!
St. Jude Donor '04-'05-'06
55 and traffic? 4th
55 without traffic, 5th
Old Oct 24, 2004 | 11:18 AM
HEB's Avatar
HEB
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Originally Posted by 14U2ENV
55 and traffic? 4th
I don't hit 6th till 65-70
Old Oct 24, 2004 | 11:19 AM
Lenskey's Avatar
Lenskey
6th!
Old Oct 24, 2004 | 11:26 AM
99C5Vert's Avatar
99C5Vert
St. Jude Donor '03-'11
55 and traffic? 4th
Old Oct 24, 2004 | 11:38 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
I don't use 6th unless I'm cruising at 75+ on flat roads.
Old Oct 24, 2004 | 11:42 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
Sure no reason not to. The only thing is there's not as much get up and go. But there should be no reason why you can't. No detrimental reason not to. Unless there's something I don't know about. You learn something new here everyday so maybe this is the one I learn on today.
Old Oct 24, 2004 | 12:08 PM
vettenuts's Avatar
vettenuts
I found I get more carbon build-up in sixth unless the speeds are up. I would tend to run the motor a little faster.
Old Oct 24, 2004 | 12:15 PM
Villain C5's Avatar
Villain C5
would leaving it in 6th get better gas mileage?
Old Oct 24, 2004 | 12:23 PM
JimAgain's Avatar
JimAgain
55 and traffic? 4th
No traffic, no hills, no hurry I would cruise at 60mph in 6th.
Old Oct 24, 2004 | 01:00 PM
dfgrdh's Avatar
dfgrdh
At 55 I tend to stay in 5th. I use 6th when I am going 65 or faster.
Old Oct 24, 2004 | 01:02 PM
BeastieBoys21
No accelleration j/k
Old Oct 24, 2004 | 01:06 PM
NSTG8R's Avatar
NSTG8R
I'm a stickler for saving gas and I get hassled if I go much over the speed limit. So I'm usually cruisin' 50ish in 6th .. 1000 rpm. Just dont hit the gas cuz she does nothing but bog. If there is traffic and you need to dodge cars, 5th.
And no, I dont believe it hurts the car. This has been done on mine for the last 33,000 miles.
oh yeh forgot to mention, I live in florida. So it's all flat.
Old Oct 24, 2004 | 01:12 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
i'm in 6th gear asap just about everywhere i go, if i'm cruising it's usually in 6th, sometimes even in traffic.
To Double Nickle--5th or 6th gear
Old Oct 24, 2004 | 01:16 PM
TkitPlz's Avatar
TkitPlz
Very helpful advice as usual. Thanks for responding! Dan
Old Oct 24, 2004 | 02:40 PM
Tom/99's Avatar
Tom/99
The owners manual states that you need to keep the RPM's above 900. With that, around town I'm in 6th about 45 mph.
Old Oct 24, 2004 | 02:41 PM
mowton's Avatar
mowton
Lower oil pressure especially at operating temp.
