Noise when turning off engine ???
Old Oct 24, 2004 | 12:28 PM
harmie's Avatar
harmie
3rd Gear
Default Noise when turning off engine ???
I have a 2002 conv. I notice that when I turn off the engine and the car is not in gear, clutch is out, I get a rattle from under the car as the engine spins to a stop. Does this indicate a problem????
Old Oct 24, 2004 | 12:43 PM
Patches's Avatar
Patches
No problem. Just a characteristic of the rear-mounted tranny. As you indicated, you need to keep the clutch pressed in when you shut it off.
Old Oct 24, 2004 | 12:51 PM
BeastieBoys21's Avatar
BeastieBoys21
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
In the manual it tells you to shift into reverse and hold the clutch in than turn the key off, no noise since i started doing that.
To Noise when turning off engine ???
