Shorten My Factory MN6 Shifter?
How much can I just cut off of the shifter threads to shorten the throw?
I really don't want to mess with re-tapping the threads if I can get a shortened throw from just removing the top part of the shifter.
What do you think?
What do you think?
If I remember right, I cut off between 3/4 and 1 inch without rethreading. I also added a flameball which is shorter than the stock ****. Works for me.
The safest way would be to use a 9/16-18 die - threaded on the shaft before cutting, but in all likelyhood, a nut will work out fine. I would also tape-seal the boot to the shaft to prevent metal scrap from getting inside.
Originally Posted by allegro
Did you thread another nut over the shifter to clean ot the threads or just "hack away?"
I did this....3/4 here..hardest part was finding the damn die
http://www.use-enco.com/CGI/INSRIT?P...&PMPXNO=944707
and
http://www.use-enco.com/CGI/INSRIT?P...&PMPXNO=943704
did it!
taped up the shaft to nearly an inch to be removed. Made a "surgical tent" to protect the interior and used my Dremmell tool. Took only a moment to cut it and the **** went right back on smoothly.
took longer to put up the tools than to make the mod.
Drove it and WOW what a difference.
I recommend this mod for all MN6 owners.
Good improvement. Half a hour to an hour. The key also has to be shortened a little. Surprised about how easy and quick it was to cut the shifter.
