[Z06] Track masters, I need your advice...
My first two events I ran on my stock, original pads and brake fluid.
Now I want to get set up right, so here's what I am thinking of doing and am looking for advice.
1. Order Ferodo pads from raceshopper.com. $168-fronts, $128-rears. They told me that they have the highest friction coeficient of any street/track pads made and handle temps above 1000 degrees. I want pads that I can keep on the car all the time and work well in both steet and track applications.
2. Order what seems to be the Z06 track rotor of choice, the Raybestos rotors from NAPA that run about $20 apiece. Everything I read on the forum seems to say that you can pay more but you can't get better for track use......
3. Get some Super Blue DOT4 fluid from raceshopper.com
4. Take everything to a local Corvette specialty shop and have them install everything and bleed the brakes for ~$250. I have no tools or desire to do any of this work myself. No way i am going to trust my absent minded self with installing something that is supposed to slow me down from 145MPH reliably........I want a pro to do it.
so, any thoughts on my choices here and is that a reasonable price for everything I am having them do?
thanks very much for the input.
Most ppl who do more then two DEs a year learn to change their own brake pads, rotors and bleed the brake fluid. All are very easy to learn.
The most popular brake pads for racing / DEs ( not in any order )
1. Wilwood H or J
2. Carbotech XP9 f and XP8 r or XP10 f and XP9 r
3. PFC-01
Unforutntly these pads dont work well on the street as they need heat to really bite into the rotor. Then change back to street pads
If you going to do more then two DEs a year, and since you have come to your scences, that corvettes are to be driven, not shinned and hidden away in a garage or parking lot. Get the tools you need and learn to do this work yourself. It is not difficult and there are pleanty of Corvette ppl that do DEs that will help you.
Heck I watched ppl for a long time to doing this work and then had them watch me do it. Now it is second nature as there have been times I had to change a brake pad or rotor with very little light to see.
jnjboc - you should hang out in the autox/rr section of the forum. You can learn ALOT over there...anything from simple pad changes, to complex race setups, to driving tips...plus, find out when all the good events are happening.
But I understand your desire to have someone else do it. I also don't want to be bothered but enjoy learning how just in case.
yes, I was going to order the Goodridge SS lines.
I'm only going with the Ferodo's since the folks at raceshopper, which I have heard good things about, say they are the best compromise between street and race specific pads.
since I'm brand new to corvettes(had my first one only 6 months), and have only been to two DE's, I don't know a lot of folks yet. Hopefully, I can hook up with some people at the track that will be changing out their pads/rotors and jump right in.
By the way a lot of these pro's including the ones who drag race have no clue about the stresses encountered by a car in a DE and just don't realize they really have to check things out. Work that is OK for the street isn't acceptable on the track.
Bill
The problem is that all the local Corvette specialty shops I have talked to(there are three of them), want to sell me their rotors, and pads, and they all suggest slotted/drilled. i explain to them that I am tracking the car and the stress is far too high for post-manufacture drilled rotors.
they seem dumfounded. They have the attitude of "well if you want to bring the parts in, fine, I will charge you straight labor rates". I'm looking for a shop that understands performance driving and gives a damn about the job being done right, and that parts are like everything else-everybody has an opinion and just because their shop does not sell Raybestos rotors for instance, does not mean they are bad...
I can't have my dealer do it as they have already told me they won't bleed the brakes and put in DOT4 fluid as they are concerned with mixing DOT3 and DOT4 which, of course, is a lack of knowledge on their part(they say that even with bleeding, some DOT3 will still be in the system and they don't want to be responsible for a failure due to DOT3 and DOT4 being mixed together???), and the fact that the owner's manual specifically states to use ONLY DOT3 fluid, so I am screwed there.
OK, so if there is anybody in my geographic area who would have the tools, experience and time to do this with me, I will gladly pay you for your time and instruction. I'll drive to where you are with my parts and we can put them on together and bleed the brakes so I can learn by doing.
Otherwise, I'm not sure how I'm going to get started into performance driving seriously.........
looking for HELP!!
At the two schools that you did do, did you met any guys that have corvettes and still keep in contact with them??
Or what is your next event and track and where do you live?? lets see if we cant get you some local help.
My mechanic races drag cars. He completely understands when I bring in a box of parts for my cars. Dealer mechanics, though good in their own right, just aren't experience with non-factory items!
I would upgrade fluid. I use ATE blue. I've put it in both my vettes with no problems mixing fluids. Nice thing about blue is you know when you've got all the old fluid out.
I wouldn't worry about using a corvette specialty shop. These brakes are so easy to replace, any reputable repair shop can do it. Get a recommendation from a friend. When I first started tracking my car, I was living in an apt. temporarily while my house was being built, so I didn't have access to a garage or my tools, so I went to a good local shop and they did a fine job. Enjoy the obsession
