Build Sheet Option Code Question
Old Oct 25, 2004 | 09:12 PM
allen150's Avatar
allen150
Default Build Sheet Option Code Question
I am looking at a copy of my build sheet, and there are several option codes that I am unable to decipher, and some that don't seem correct.
All of the options listed are in the car, but I'm not sure if I have active suspension. I thought that was the 3 position switch that I don't have, but that is called selective realtime damping. Also UZ6 seems out of place. It says it is for a fixed roof coupe and I have a Targa Coupe.
I found the option codes here:
http://www.idavette.net/facts/99.htm
Any ideas as to what the other option codes are?
Thanks, Allen
option codes
AAB - Memory Package $150
AG2 - Power Passenger Seat $305
AK5 -
AQ9 - Sport Seats $625
BGR -
B34 - Floor Mats $25
B84 - Body Side Moldings $75
CC3 - Removable Roof Panel Blue Tint $650
CJ2 - Dual Zone Air Conditioning $365
DL5 -
DL8 -
D42 - Luggage Shade and Parcel Net $50
FE3 - Sport Suspension (included with Z51)
FE9 - Federal Emissions
GU6 - Std. Axle Ratio 3.42:1 Six Speed
IL3 -
JL4 - Active Suspension $500
JL9 -
K63 -
LS1 - Std. 5.7 Liter SFI Aluminum V8
MM6 -
MN6 - Six Speed Manual Transmission $815
NF2 -
NK4 -
N37 - Power Tilt and Telescopic Wheel
QD4 - 17" Std. Wheels
R9Z -
T82 - Twilight Sentinel
T96 - Fog Lamps $69
UN0 - Stereo System Delco-Bose with CD $100
UV6 - Heads Up Display
UV7 -
UZ6 - Std CD 4Spk-Mast Antenna- Fixed Roof Cp
U52 -
VM3 -
V49 - Front License Plate Frame $15
V73 -
XGG - Front Tire - P245/45ZR17 BW SBR
YGH - Rear Tire - P275/40ZR18 BW SBR
Z51 - Performance Handling Package $350
1SA -
10U - Arctic White
19I -
193 - Black
Old Oct 25, 2004 | 09:44 PM
GrayC5's Avatar
GrayC5
UZ6 is the RPO Code for Speaker System, 6, Quad Front Door Mounted, Dual Quarter Mounted (or the Bose speaker system).
This is one of the more comprehensive lists I've found: C5 RPO Codes
Hope this helps.
Old Oct 25, 2004 | 09:59 PM
GrayC5's Avatar
GrayC5
Just noticed and looks like the the Idaho Corvette link you posted has some errors in it. Try the link I posted and see if that helps.
Old Oct 25, 2004 | 10:41 PM
allen150's Avatar
allen150
Thanks for the link. The Build Sheet really is the Build Sheet, very comprehensive.
Allen
Old Oct 25, 2004 | 10:54 PM
GrayC5's Avatar
GrayC5
Allen
Yes, they are. We have one of the original copies of our build sheet that was presented to us by one of the plant workers as part of our Museum delivery. IMO, the build sheet is a very nice piece of documentation for any Corvette owner/enthusiast to have.
To Build Sheet Option Code Question
