[Z06] Rear Differential Leak
Old Oct 26, 2004 | 04:29 PM
Orlandoz06's Avatar
Orlandoz06
Default Rear Differential Leak
I own a 01 and just read in a thread something mentioned about leakage, I know about the oil consumption issues but this is the first time this has come to my attention. Any thoughts or info would be appreciated.
Old Oct 26, 2004 | 06:02 PM
2K3Z06's Avatar
2K3Z06
From: KADS- If it has wings or an engine, I can break it. Dallas TX
It seems the drivers side differential cover o-ring does not seal very well. Pretty common problem. There is a new re-designed o-ring that suppose to be the cure. The guy at the chevy house that did mine (at 5000 miles) used silicone sealant. No more leaks.
Old Oct 26, 2004 | 08:34 PM
barondw's Avatar
barondw
There are several TSBs on the leak. They have trried sevral attempts at fixing the lastest being a new seal and sealant.
Very common even if you do not see drippings on your garage floor. Pays to do an underneath inspection every several months.
Old Oct 28, 2004 | 01:20 AM
CRWDDYZ's Avatar
CRWDDYZ
Just noticed mine dripping on the garage floor at 6k miles on my 04....will be making an appointment with dealer tomorrow...I am glad it is a known problem with a TSB...I have read it many times here...
Old Oct 28, 2004 | 08:23 AM
dwjz06's Avatar
dwjz06
Dogface
St. Jude Donor '15, '17
Yep. Just had mine done. The fluid was not hitting the floor yet. Just crud all over the back of the suspension parts. I found it last oil change. They used the new seal. I went to look at it yesterday and will pick it up today.
Old Oct 30, 2004 | 02:43 AM
CRWDDYZ's Avatar
CRWDDYZ
Default Rear Diff Leak with Pics and Fix Pics
Just got mine back from the dealer today after the fix. 2004 Z06 with 6k miles.
Click-----> C5 Rear Diff Leak Pictures
Last photo has the part numbers involved with cost. Mine was under warranty.
Old Oct 30, 2004 | 10:04 PM
Boomer 2's Avatar
Boomer 2
Mine had to be replaced at about 8k miles. No big deal, the General fixed it for free.
To Rear Differential Leak
