Oil Temp?
Oct 26, 2004 | 09:39 PM
Oil Temp?
Out on the open road what temp does your oil usually stay at?
Oct 26, 2004 | 09:41 PM
200F - 210F .. but I've come to realize mine runs hot.
my coolant temp (as long as I've turned on the A/C) stays at around 195F
This is driving on the hwy, at 80ish btw.
Oct 26, 2004 | 10:00 PM
St. Jude Contributor
Obviously depends somewhat on the weather....usually about 200-210ish in the summer.........unless I'm in the throttle some....then it comes up pretty quick.
Oct 26, 2004 | 10:37 PM
Cruise-In VII Veteran
St. Jude Donor '06-'07-'08
it runs around 200 almost all the time, did the dragon last month jumped
220 then cooled back down.
hope this helps
Oct 26, 2004 | 10:41 PM
mine runs 200-220. under hard conditions i've seen it get up to 230.
Oct 26, 2004 | 10:51 PM
Checked mine today while on a 50 mile drive. Temp was betwwen 200 and 210. Outside temp was about 45.
Oct 26, 2004 | 10:56 PM
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Normally, 210-220, but I've seen mine as high as 245.
Some of the roadracing guys are seeing 260+, and that's still within acceptable limits of the oil.
Oct 27, 2004 | 08:33 AM
Quote:
on the street, I'll usually start backing off at 250'F (notice where I've from)
on the track, i start to back off at 275, and will not let it get past 280.
Oct 27, 2004 | 08:44 AM
Those are normal temps for a stock C5
