recall done, now get pull key wait 10 sec.
I had the column lock recall done on Tuesday (an A4)...this morning the car stalls while backing out of the garage. The DIC says pull key, wait 10 sec. I pull key but don't wait 10 sec. Stalls again, same error message. This time I wait 10 sec. It started, ran well, got me to the dentist
and home.
I cought the tech getting out of my car on Tues. and asked him if he took my CLB out for me. He had no clue of what I was talking about. He said "All I did was cut a couple wires and pull a relay" and claimed not having to get behind the lower dash. - so, my CLB is still in there.
The paperwork says:
recall 04006 - electric colum lock system - recall done - replaced steering lock in the column and spliced in a new harness.
FP # 88952427 - Description: harness K 2.195
Has anyone had this happen?
thanks
Sorry to hear about your problem. What a frigg'n disaster this whole column lock issue is.
If your paperworks says that a "harness K" was installed, I am confused as to how that could have been done with the tech "not having to get behind the lower dash". I am not a tech so maybe it is installed elsewhere, but I doubt it.
But, if the harness is installed, and the CLB is still in there then perhaps this could be the cause of your problem. I don't believe that I have ever read a column lock thread where an A4 owner has had both the CLB and harness K installed at the same time (not that I have read every thread on the column lock issue - I don't believe I will live that long). I don't think you need, or want, both.
Also, I thought that the recall (for an A4) required installing a plate to block the locking pin (or removing the pin itself). Would the tech have to get behind the lower dash to do that?
Anyway, you might want to try removing the CLB (if in fact the harness K is installed) and see if that fixes the "wait 10 sec." problem.
Good luck, and let us know how it turns out.
tells me he didn't have to get back there. << shrug >> Shortimer - the MN6 fix is to reflash the 'puter. a lot of forum users put the CLB right back in afterwards.
If I do anything, it will be the bypass or plate removal. I need to find out how to do the latter.
I still have my recall letter in the C5's trunk somewhere.
Bypass prevents lockup.(Aftermarket only)
The fuel cutoff is for MN6 only since GM cannot disconnect the column lock on those cars.
For this specific problem, I would assume the k-harness would effectively disconnect the CLB even if it were left in there (i.e bypassing the bypass). It sounds like the harness may be causing the problem or it just wasn't installed right.
1. What is a CLB
2. What exactly is the column lock recall
My car is a 6 speed and I just found out it didn't have the recall done.
Thanks for your help
I think (as JC stated) that harness was installed incorrectly (since the tech's work is already in question if he did not work on the locking plate), or as I mentioned earlier, having the harness and CLB installed at the same time (if the harness for some reason does not "bypass the bypass-CLB"
) pisses off the PCM (or BCM). Just a thought.harley, CLB stands for Column Lock Bypass. The columm lock recall is a half azz'd attempt by GM to fix (actually work around) a PITA problem where the car thinks it is being stolen and locks the steering column and will not let the car be driven. That is a very over simplified explanation, but if you do a search on "column lock" you'll get more information than you will live long enough to read
1. What is a CLB
BTW, a little friendly advice since you have an MN6, get the recall done (just so it is shown on record as having been done) ASAP and then buy a CLB and install it immediately. Better yet, buy the CLB first (don't install it) so that you have it ready to install right after the recall is completed. It is simpler not to have to even talk to the dealer about a CLB (most will either "be" or "play" dumb anyway).
The only thing that is actually done to an MN6 car is reprogramming the PCM to shut off fuel flow if the car enters this condition where it thinks it is "being stolen" (for lack of a better explanation). They should also do a visual inpection of the locking pin, but neither of these will prevent the condition from occuring in the future. The CLB will
The 88952427 relay harness kit is installed under the left dash and plugs into the same harness (in series)that the CLB plugs into.Also,there is no splicing or removal of a relay on the A4 recall.
The procedure also involves installing a dummy lock plate in the column in place of the original lock plate.The recall on the 98-2000 M6 involves installing (splicing) a jumper harness at the BCM under the right dash,and removing and reinstalling an updated column lock relay.I am confused though because the part # for the M6 kit is 88952428,not the # billed on your recipt,if the wrong kit and procedure was installed.
