Mobil 1 Synthetic ATF for a M6?
#41
1997-2000 C5s have paper blocker rings. DO NOT use Mobil 1 ATF, I did and had grinding going into 6th gear after 50,000 miles of running it. I switched to Amsoil ATD and it immediately stopped.
Nobody "ruins" the 6th gear syncros, it is not like I speed shift into 6th gear. It had to be the fluid !
#42
I'm just curious? Reading through some other threads on this subject, how can you tell if your synchros or blockers or your transmission is functioning correctly or not with the synthetic fluid installed? Not being funny, but how can you tell? Some people who swear the synthetic fluid is screwing up thier transmission. Just don't know?
Lap
Lap
It "seems" like it's a little too slippery to let the synchros do their job,but I don't know if that's why it made my Vette shift like an old tractor.
Every since I drained it and refilled with "the cheap stuff",It shifts like a Vette's supposed to shift.
It is possible that the GM folks who made up that little "DexronIII" tag by the fill plug on the tranny knew what they were talking about....
#43
Would you guys recommend using the Mobil 1 Synthetic ATF in a 6 speed car? Ive got a 97 with 50k miles on it now, and the shifting between first and second are becomming really "notchy." Ive heard that its the "norm" to use ATF in M6 gearboxes...i just want to be 100% sure before i put it into my baby.
#44
It didn't screw mine up-it just didn't shift as well with Mobil 1 as it does now with El-Cheapo Valvoline Dexron 3
Lap
#46
Per many posts here on the forum,,,,the ONLY synthetic ATF fluids safe for the older C5 M6's(97 through 2000) is Royal purple and Amsoil!! Mobile! and others are reported to ruin the fiber facing on the synchro blocker rings!! later models got carbon fiber facing that work with any fluids.
#49
From what i got out of this section is that if you have 97-00 be careful of what oil you put in your m6. If you have newer it's not an issue.
#50
Lap
#51
I didnt want to find out if the Mobil 1 ATF worked on my 99 mn6 (stock tranny) so I just used Castrol Dex domestic multi-vehicle ATF (non synthetic). It works normal, no problems, shifts like stock with over 77K miles on it. FYI, my car is supercharged.
I recommend you use it or any other non synthetic that meets Dex III requirements. If you want to use synthetic, then I recommend using a brand that has no history of paper blocker problems (ie: Amsoil), and call it a day.
http://www.castrol.com/castrol/mispo...ATF282_648.jpg
#52
I read all this 3 years and 65K miles ago and went with Amsoil ATD in my '98 M6.
No problems.
Why risk it?
#53
WHAT!?!?!?!?!? I am completely lost here. i thought the paper blocker rings subject had been beaten to death, and we all concluded that 97 to early 01 models did have the paper blocker rings in the m6 transmission. 99% of all reputable sources i have seen state the same thing. The only sources where i have seen conflicting information is from some not so reputable shops.
All synthetic oils cause cellulose compounds to expand. Paper is cellulose. The blocker rings are paper. The blocker rings are cellulose.
Amsoil synthetic ATF or ATD has an additional chemical that makes cellulose compounds contract, therefore counteracting the swelling effect of the synthetic oil, and NOT causing the blocker rings to expand.
Amsoil ATF or ATD is the ONLY synthetic fluid i will use in my pre-2001 m6 transmission that has paper blocker rings.
#54
#55
I asked the same question of Mobil Engineers, and they said they had heard of no problems with Mobil 1 ATF and early C5s. They should come to this Forum ! I had problems with Mobil 1 and my 1998 C5 MN6 after 50,000 miles running it.
#56
I'm at 58,000 miles on my 99 with Mobli 1. What problems did you have with your 98 C5?
#57
We really need to get to the bottom of this.
I spoke with forum member RoadRebel (Dr. Phil), and he is recommended as one of the best corvette mechanics and tuners in the country. He spent 14 or so years as an engineer at GM, and he had the same opinion as me as far as the sythetics/swelling, and amsoil fluid goes. I would trust him over any tech rep. I would also trust a lot of certain forum members here over any tech rep.
Also, from most of the posts i have read since i've been a member here, the damage from using non-amsoil synthetic fluid doesn't show up until around 50k miles later after using the fluid. Just because you notice a difference after first changing the fluid does not mean its good for your car.
#58
I use Royal Purple in my differential and tranny. They are an excellant choice.
Max-ATF for the transmission
http://www.royalpurple.com/prodsa/matfa.html
Max-Gear for the differential
http://www.royalpurple.com/prodsa/mgeara.html
To help you with you question and apparent confusion.
Your 6 speed manual DOES indeed use Dexron III ATF fluids.
This is what I use as well. No problems in 10,000 miles since changed. It did add a little smoothness back to the shifting feel.
#59
