Is there any difference in the clb from corvettes of huston or thunder racing??
I just installed mine yesterday. Bought it from Thunder racing.
Don't know about huston, but it only took about a half hour to install it.
It worked like a charm, they also give you a web page with pictures for step by step directions.
I have a 99FRC.
Good Luck,
Jeff
I bought mine fron houston. It;s all the same it's just an electronic box that keeps a circuit open or closed. Most important is that I'll never be whining about getting stuck somewhere. just do it!
Mine was from Thunder Racing. They call theirs a CLS (Column Lock Simulator) They may look a bit different but never heard of any operational difference.
I got the Harness K which is from GM the fix for the A4. I have heard their might be issues down the road with the CLB because it's resistance load is different from the CL. So I decided to get the Harness K for $10 more. I actually got it from a forum member that got it from GM parts direct. There's my .02
