Passenger Window Problem
Old Nov 2, 2004 | 05:01 PM
JOHN MOORE's Avatar
JOHN MOORE
Default Passenger Window Problem
Have a 2000 coupe w/both tops. Passenger window does not seal to the weatherstripe properly on either top (glass top is better than solid top). Like to keep the solid top on because I drive the car, but the wind noise is a problem at highway speed, and there is a small amount of leak if its hard rain. Is there any adjustment? I've taken it to a couple of local body shops and they both indicated they really didn't want to mess with it because it often makes the problem worse. Any suggestions?
Old Nov 2, 2004 | 07:11 PM
Frby98's Avatar
Frby98
I have the same problem with mine. I talked to a local guy (Corvettes & Classics - Greer, SC), and he said that he could fix it by adjusting the tracks on the glass inside the door. Only about 2 hrs labor ($100-150). Does that sound reasonable to anyone?
Old Nov 2, 2004 | 07:26 PM
JimAgain's Avatar
JimAgain
It's easy. Do it yourself. I tightened up the window on my Z. Much less than 2 hours and it should do the trick.
Here ya go:
http://www.***-internet.com/johndenn...ow_tip_in.html
Good luck
Old Nov 3, 2004 | 08:09 AM
JOHN MOORE's Avatar
JOHN MOORE
Thanks.
To Passenger Window Problem
