Best Method For Visor Sticker Removal?
Nov 3, 2004 | 07:35 AM
what are some ways to safely remove these stickers from the sun visors?
Nov 3, 2004 | 07:43 AM
I have seen this posted several times, but all I did was simply pull the sticker off. Came off fairly easy and did not leave any residue.
Nov 3, 2004 | 08:12 AM
thanks. i was going to do that but the sticker isn't cooperating that easy.
Nov 3, 2004 | 09:34 AM
Use a hair dryer to heat it up a little. It should peel off much easier after that.
Nov 3, 2004 | 10:01 AM
Quote:
That seems to be the most recommended method!
Nov 3, 2004 | 12:50 PM
A hair dryer works pretty well to soften the adhesive and let you pull it off. Sometimes though they can be a real pain to get off.
Nov 3, 2004 | 12:54 PM
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Mine came off with no problem and no residue - just lucky, I guess. 01 A4 Coupe
Nov 3, 2004 | 12:58 PM
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Even if you hae some residue adhesive left over, Goo-Be-Gone + a clean terry towel = completes the job.
Nov 3, 2004 | 01:21 PM
I used the hair dryer but some residue remained on my 2004. After trying a lot of different things I used balled-up duct tape and it removed all the residue.
Nov 3, 2004 | 01:55 PM
St. Jude Donor '11-'12-'13-'14-'15-'16
If you decide to keep your car for many years you will wind up spending big bucks buying that sticker to put back on to make your car correct for NCRS certification. (LOL)
Nov 3, 2004 | 06:28 PM
Thanks to all for your comments.
