[Z06] Low oil level on barely driven 02
Old Nov 4, 2004 | 01:50 AM
EVIL ZO6's Avatar
EVIL ZO6
Default Low oil level on barely driven 02
The car has less than 9K on it and I have probably only put 2-3K miles on it this season. Tonight she is telling me the oil level is low. I get home and check it, sure enough quite low. How the hell can this be? I havent driven the car very much or very hard at all, yet she is at least probably 2qts low? DIC says over 60% oil life remaining as well. Is she developing a ring problem?
Any thoughts?
Old Nov 4, 2004 | 07:13 AM
hoogbest's Avatar
hoogbest
Default Low Oil
Check the dip stick. It has sensors on it and it may be out of wack.
Old Nov 4, 2004 | 07:54 AM
barondw's Avatar
barondw
Several other obvious things to check:
1. Is there oil residue on the exhaust tips and back of the car.
2. Are there any drippings under the car? If driven seldomly I assume it is garaged in one place.
3. Is the dip stick properly seated and is there any oil around the dip stick?
4. Are valve cover free of oil?
5. Is oil filtered properly atatched and not leaking?
6. Is drain plug tight and not leaking?
That should keep you busy for a few minutes. Good luck.
Old Nov 4, 2004 | 09:00 AM
98Pacecar's Avatar
98Pacecar
A couple factors to consider. How many miles since your last oil change? Based on your DIC info I would assume 4,000?? How low are you on oil? You may only be one quart low, which would not be out of tolerance for 4,000 miles.
Old Nov 4, 2004 | 09:38 AM
Thud's Avatar
Thud
I know that every time I leave the car parked downhill for a period of time, the "low oil" reading will come on, even if the oil level is full.
Old Nov 4, 2004 | 09:43 AM
GotMoJo's Avatar
GotMoJo
Depending on your driving style these cars can and will use some oil. I go through a quart about every 3000 miles.
Old Nov 4, 2004 | 01:16 PM
EVIL ZO6's Avatar
EVIL ZO6
Of course it is not leaking from anywhere, that was my first thought.
I also am aware that these cars burn oil, but for this problem to just materialize after a few years of NOT having this problem is strange to me.
Old Nov 4, 2004 | 01:59 PM
barondw's Avatar
barondw
I agree these cars do not burn oil, including using them at DEs. yes it is strange that is why I asked about looking for evidence of leaks.
Old Nov 4, 2004 | 03:39 PM
Wolf Dog's Avatar
Wolf Dog
I realize this is not an answer per se but by the time my '02 had about 8000 on the odo, it started burning oil in large amounts...not in flat city or highway driving but after lots of accel/deccel such as going over the hills to the coast or up to the Sierras. The oil was topped up before I left for Yosemite once, by the time I got there the warning lite was coming on. Nothing showing on the dip stick. No leaks, no smoke out the back, no smoke when starting hinting that it might be blowing past the valve guides...nothing. Pipes were clean. I had not tracked it by that point so don't know how it would have burned it under those conditions. About 12k miles later however, a weak valve spring finally gave out throwing things all over the engine. Chev. replaced it with an new crate motor. I have tracked it extensively since, made the same drives and it doesn't burn much if anything between changes. I know the weak spring probably caused the valve to float a bit, and an overall decrease in power but I don't see how that could have contributed to the oil consumption. Perhaps someone here(probably everyone) who's a much better mechanic than I could explain it. Oil consumption can often be hard to diagnose.
Old Nov 4, 2004 | 05:53 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
I had my '01 re-ringed and it burns maybe 1/2 qt in 5000 miles w/ HPDE's, drag racing, and 1/4 action...
Have the dealer check you valley cover (below the intake mani) there's a seal that can be bad and cause major oil eating. It's the main cause of oil eating on '02+ cars b/c it's no longer the rings.
Prior to my re-ring, the replaced the valley cover first and that cut down the oil consumption a bunch, but it still burnt, so I had the rings changed. Now she's stronger than ever.
To Low oil level on barely driven 02
