Storage question
Old Nov 4, 2004 | 08:15 AM
Pewterboy's Avatar
Pewterboy
Navigator
Default Storage question
My buddy and I are arguing over this. He says when you store a car over the winter you have to start it every 2 weeks, and let it run for 15 or 20 minutes. I say pull the battery and untuck it in the spring. Any opinions? One more quick question, how do I tell what month my car was built in? I have an 01 and it dosen't seem to burn oil that bad.
Old Nov 4, 2004 | 08:33 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
there are many threads here talking about winter storage so you might want to search them for more advice, but here is my .02..
You can store it all winter without starting it. I have many friends in Minnesota and in Upstate NY that bring their cars to a storage place which locks the doors in November and does not open them until the Spring. They dont even have the option to sart it.
I would recommend using a battery tender to keep your battery charged up during the tinme that your car is not started....
Old Nov 4, 2004 | 09:18 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Most everyone here just seals them up tight and comes back in the spring or like I do, if the weather is good and the roads are clear I drive her. I've read it's not usually recommended to start the car and let it run without driving it because leaving the car running with out driving it may contribute to condensation issues. I can't say this is true, but just what I've seen. As far as the battery, you can pull it or get a battery tendor for long periods.
As far as your born on date. You can try to PM member Sponge Vette and if he has a chance he can get your build date and option information for you. You can also just post a request on the forum, he reads them and replies when he can. He's done it for several of us. Here is his profile.
http://forums.corvetteforum.com/member.php?userid=55505
Paul
Old Nov 4, 2004 | 09:20 AM
sharpvet03's Avatar
sharpvet03
without going into every detail,you are right-store it and forget it..
Old Nov 4, 2004 | 09:44 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
As above don't worry about it. I use extruded styrofoam under each tire to stop the tires from flat spotting. Works great. Get 2" and cut bevels on the pieces so you can drive up onto them. And pump the tires up to between 35 to 40 psi. Nighty night.
Old Nov 4, 2004 | 12:50 PM
xwing's Avatar
xwing
About the only thing I do is park the car on carpeting (to prevent bald spots on the wheels) and cover it with a car cover.
Old Nov 4, 2004 | 01:27 PM
SavPrato's Avatar
SavPrato
I just put mine away (with a battery tender ) and forget it. I also inflated the tires to 40 PSI to avoid flat spotting.
Old Nov 4, 2004 | 05:48 PM
JC in XTC5's Avatar
JC in XTC5
I hook it up to a battery tender and will take it for a drive maybe once a month if the roads are dry.
Old Nov 4, 2004 | 06:36 PM
Store it and forget it, unless you plan to actually drive it a bit. I use a battery tender on mine, Sta-Bil in my gas and put some carpet squares under the tires. But, if I want to drive it, I do.
Old Nov 4, 2004 | 06:45 PM
BeastieBoys21's Avatar
BeastieBoys21
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
this is a stupid question but do all battery tenders have to be plugged in or are there any other options to keep the battery charged. Unfortunaly i have no electric in the garage (yet)
Thanks,
Mike
Old Nov 4, 2004 | 07:13 PM
Old Dog's Avatar
Old Dog
Thanks,
Mike
As far as I know you need power for them all. I had the same
problem you have the first winter I stored mine. I had to run
a power cord over to it about every three weeks for a day or
two to keep the battery up. It is worth the effort.
The only other thing is to take the battery out and keep it
on the charger in the house.
Good luck, winter is here!!!
Old Nov 4, 2004 | 07:17 PM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
I agree use a battery tender that's what i do then you don't have to start the car at all for the whole winter storage time.
Old Nov 4, 2004 | 08:53 PM
rkhegler's Avatar
rkhegler
Paul
I agree. I drive mine when the roads are dry and there is no chance of ice or snow. I would not recommend letting it idle for 15 to 20 minutes. You need the oil temp to get about 190 degrees. You have to drive it to do that.
Old Nov 5, 2004 | 10:54 PM
RedWolf's Avatar
RedWolf
CI 6-7-8-9-10 Veteran
St. Jude Donor '08-'09
I store mine with a battery tender and start it every couple of weeks for 30 mins. No trouble getting the oil temp up to over 200 degrees. Rev it up some (feels good). You need to get that oil temp up to keep the moisture out. I make sure the heater is on, run the A/C a little, turn the wheels some to circulate the power steering fluid and pump the brakes as well.
To Storage question
