How to raise window adjustment?
Old Nov 4, 2004 | 04:25 PM
04Magnetic's Avatar
04Magnetic
Default How to raise window adjustment?
I need to raise the window on my passenger side. It was adjusted too low at the dealership and now I have wind noise. They adjusted my drivers side perfectly. I cant get back to the dealer till next week and need to do this asap. The tip in looks fine, I know how to adjust that, I need to have it up a bit more. Anyone?
Old Nov 4, 2004 | 05:16 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
i just watched a leak guy perform what you need at the dealer on my 2000. dont have a door diagram but if someone posts one i will identify the part. its just a matter of a slide bolt adjustment.
Old Nov 4, 2004 | 05:29 PM
Patches's Avatar
Patches
Window Height Adjustment - Door Minor
Use this procedure when window height is off less than 3 mm (0.12 in).
1) Open the door and remove the small front access plug and the rear access plug from the underside of the door.
2) Adjust the front and the rear window regulator jack screws equally.
3) Close the door and check the window alignment.
4) Open the door and install the access plugs.
Old Nov 4, 2004 | 05:47 PM
mrm1149's Avatar
mrm1149
i cannot discern the part i spoke of in the diagram above. once you get the door panel off , pull back the rubber? piece that is maybe 15"sq.at the aftmost portion of the door. there is a grey plastic box that might remind you of an octagon electrical box. there is 1 hex head bolt that slides up or down in a notch. hope that makes a little sense..........sorry i can't help much more........ it may be part #16
Old Nov 4, 2004 | 08:28 PM
04Magnetic's Avatar
04Magnetic
Perfect
The adjustments were around #52 and #26.
I least I have no fear in ripping my car apart at 8pm on a dark rainy night.
No more wind noise
Thanks for the tip and diagram, made my day and weekend.
Old Nov 4, 2004 | 09:43 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Good to know. Great place this is. Thanks Patches for the pics.
Old Nov 4, 2004 | 10:03 PM
Fuzzy's Avatar
Fuzzy
Were you able to do it through plug hole in bottom of door?
Old Nov 4, 2004 | 10:32 PM
JLinCA's Avatar
JLinCA
Just had mine done at the dealer. I don't know what they did, but both my doors are out of wack, especially the passenger side.
Are the door hinges adjustable??
Old Nov 5, 2004 | 09:04 AM
04Magnetic's Avatar
04Magnetic
Only the tip in adjustments can be made through the plug hole and behind the reflector.
Up/Down adjustments need to be made in the door itself, requiring the door panel to come off. It just took time to make small adjustments, tighten it up, check it, readjust, tighten, check.... yadda,yadda,yadda....
To How to raise window adjustment?
