Hydrolock------
Old Nov 5, 2004 | 11:47 PM
Qcksilverc5's Avatar
Qcksilverc5
Default Hydrolock------
What is it?
Old Nov 5, 2004 | 11:53 PM
PHPD7102's Avatar
PHPD7102
St. Jude Donor '14-'15-'16
Car ingests water through the intake and fills the cylinders with water, motor locks up. Usually accompanied by all kinds of bent and broken stuff in your valve train. Not nice.
Old Nov 5, 2004 | 11:55 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
A watered down version of a Thread Lock? You'll see an example shortly Sorry. Couldn't resist ... what he said.
Old Nov 5, 2004 | 11:57 PM
C5naples's Avatar
C5naples
Water does not compress, things bend and break!
Old Nov 6, 2004 | 12:01 AM
Qcksilverc5
Default Thanks guys!
Was just curious---
Old Nov 6, 2004 | 11:21 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Yeah the car is a bottom feeder so don't go through any deep water puddles. Not a good thing.
Old Nov 6, 2004 | 02:09 PM
Man 'O War's Avatar
Man 'O War
I had it happen to me on accident when turning into a parking lot. (There was about 8-9" of water gathered in a little puddle that I didn't see in time as I was turning in.) My BPP intake sucked it right up and I broke connecting rod #7.
Old Nov 6, 2004 | 03:28 PM
RPOZ51's Avatar
RPOZ51
From: For the strength of the pack is the wolf . . . . . . and the strength of the wolf is the pack.
Default Now You Have Me Worried
Is there any way to diagnose this?
I was forced to boldly go through some high standing water about two miles from home.
I have driven a few miles since then, with no symptoms.
Would you know right away, or could this be a ticking bomb?
Old Nov 6, 2004 | 03:33 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
You'll now right away. Thank god it has not happend to me,,but I have seen and heard it happen to others..not pretty
Old Nov 6, 2004 | 03:41 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Yep, that about covers the Hydrolock
Paul
Old Nov 6, 2004 | 03:45 PM
talon90's Avatar
talon90
NCM Ambassador
From what I've heard you'll know it when it happens. It is not as much of a problem on cars with stock airboxes and intakes like the blackwing and the stinger, It's a real problem with intakes like the Vararam or the Halltech Tunnel ram which draw air from way down the bottom. Still a safe bet to avoid standing water whenever possible.
Paul
Old Nov 6, 2004 | 03:46 PM
BeastieBoys21's Avatar
BeastieBoys21
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
I just installed a vararam...hope this never happens to me
Old Nov 6, 2004 | 03:47 PM
PHPD7102's Avatar
PHPD7102
[QUOTE=RPOZ15]Is there any way to diagnose this?
Would you know right away, or could this be a ticking bomb?[/QUOT
Easy to diagnose, your car will shut off and if you try and start it the motor wont turn over at all, keep trying and the burning smell will be your starter burning up.
Theres no trick to this one guys the motor completely quits, dead, "locked".
Old Nov 6, 2004 | 03:49 PM
RPOZ51's Avatar
RPOZ51
Paul
Well, I'm running bone stock, and haven't noticed any signs.
Keeping my fingers crossed, and avoiding water from now on. (My other car is a pick up truck, so sometimes I forget.)
Thanks to everyone for all the help.
Sorry if I highjacked the thread.
Old Nov 6, 2004 | 04:00 PM
02ElectronZ's Avatar
02ElectronZ
Default Water in the engine?
Check your oil. If you are running MobilOne, it may not turn milky like regular oil does when water gets mixed in with the oil. Check you air intake for water also.
Old Nov 6, 2004 | 05:05 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
You should be fine. If there really were a problem, you would have experienced a lot of grief before now.
Indeed, you would be explaining to us just what hydrolock is
For assurance, you may want to go out and check your air filter to be sure that it is not wet or damp. If so, then replace it.
Old Nov 6, 2004 | 06:17 PM
WhiteC5Vette's Avatar
WhiteC5Vette
St. Jude Contributor
You will know the instant that the engine locks up, and you come to an abrupt stop. Lucky thing is that it is normally covered by insurance, unless you are off-roading across the Mississippi.
Old Nov 6, 2004 | 06:29 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
To Hydrolock------
