Electrical Nightmare please help
Old Nov 6, 2004 | 11:41 AM
mikej1957's Avatar
mikej1957
Default Electrical Nightmare please help
Symptoms -
Passenger door will not operate from either side of car
Passenger mirror will not operate
Passenger door will not lock from either side. It will however unlock
Driver's side - window will not operate
can unlock both doors from drivers side but cannot lock wither
driver's side mirror works
Drivers seat operates manually. Will not "retract" when key is taken out and memory does not seem to work.
Any ideas?
I have replaced one headlight motor, A/C blower, wiper motor, two steering colums recalls, two window regulators and now the damn windows are not working againe,,, see above,,, nor are the door locks working, etc.
Any ideas
Old Nov 6, 2004 | 11:42 AM
mikej1957's Avatar
mikej1957
Default Nightmare
I am really in a pickle guys and need any help you might come up with.
I am really afraid to go to the dealer again
Old Nov 6, 2004 | 12:07 PM
NJblackrose92's Avatar
NJblackrose92
I am NO expert, but had almost same issue in my 1992. Replaced the computer, and all was well. Sounds like you've replaced almost everything else.
Wish I could be more help, someone on the forum will have an answer. Good luck and sorry about the problem!!
Old Nov 6, 2004 | 12:33 PM
mikej1957's Avatar
mikej1957
Default Nightmare
thanks for replying.... Posted pretty much the same thing a few weeks ago and got pretty much NO response.... looking better this time
Old Nov 6, 2004 | 01:29 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
your door controle module is bad, its a very common problem, or you have pinched wires ( green and orange ) in the accordian rubber duct in the door jam below the A pillar.
Old Nov 6, 2004 | 02:14 PM
mikej1957's Avatar
mikej1957
Default Noghtmware continued....
I would agree but I got a used passenger side one from Gene's Karshop and he said he tested it. Put it in and all is exactly the same. This is a $250+ part from GM.... ~$150 from GM Parts Direct. Not sure what to do now.
Old Nov 6, 2004 | 02:44 PM
HummelS's Avatar
HummelS
Patches can correct me if I'm wrong, but which DCM did you replace - I think the left DCM acts as a "master" in the system.
Old Nov 7, 2004 | 11:54 AM
mikej1957's Avatar
mikej1957
Default Nightmare cont'd
I repaced the passenger side one...
I know nothing about driver's being "master"
Anyone else have ideas?
Old Nov 7, 2004 | 01:00 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
First thing you need to do is check the DTC history log to see errors on the DCM, then we can go from there.
Old Nov 7, 2004 | 01:19 PM
PaceThis's Avatar
PaceThis
Yes, the first thing you should do in this situation is check your codes...if you don't know how to do this, see the tech tips section
Let us know what errors come up, especially those marked as "C" which stands for Current.
Old Nov 7, 2004 | 01:24 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
I would also check the computer under the passengers side footwell. Also see if the battery is leaking. Keep us posted.
Old Nov 7, 2004 | 01:31 PM
white top's Avatar
white top
Suggest you check all grounds. Takes a little time to do but it is cheap.
Jerry
Old Nov 7, 2004 | 01:32 PM
PHPD7102's Avatar
PHPD7102
St. Jude Donor '14-'15-'16
This could very well be the BCM. I have seen including mine some wierd reactions form the car when those short out/ go bad.
Old Nov 7, 2004 | 01:49 PM
NSTG8R's Avatar
NSTG8R
check the codes. go from there.
Old Nov 7, 2004 | 01:57 PM
eddie44's Avatar
eddie44
St. Jude Donor '03
best place to start. Good Luck and keep us posted!
Old Nov 12, 2004 | 07:20 PM
mikej1957's Avatar
mikej1957
Default Nighmare getting better
Well it is not completely over but most of the things are working now. I gave up and took to dealer. They found a loose ground somewhere.... never did say where but they promised they fixed something. Now they tell me that the window regulator I put in ~6-8 month ago is bad. A lot better than I was though. Due tomileage on car, GM would not "work with" me but did offer an owner loyalty certificate. That means a new vehicle and I am not as wid as most about C6. Anyone know where I can find a new 2004 with 6=speed in Atlanta area?
thanks for help guys
Old Nov 12, 2004 | 08:20 PM
jerrymcb's Avatar
jerrymcb
Try Monica at Maxie Price. The last I knew they had some Z16's.
Old Nov 12, 2004 | 09:30 PM
VLVETTE's Avatar
VLVETTE
To Electrical Nightmare please help
