Stereo Power On THUMP
Old Nov 6, 2004 | 12:01 PM
marksr's Avatar
marksr
Default Stereo Power On THUMP
Anyone having a problem with the C5 Bose stereo giving you a power "thump" when the ignition is first turned on? This is happening even with the volume down. Most stereos have a power-on mute to avoid this surge.
Old Nov 6, 2004 | 12:12 PM
BigJoe's Avatar
BigJoe
Nope, not in the 4 C5s I've had. First I've heard of it in fact.
Old Nov 6, 2004 | 03:59 PM
Mallory's Avatar
Mallory
Sounds like a ground issue.
Old Nov 10, 2004 | 04:14 PM
dr_nitrox's Avatar
dr_nitrox
Default Thump
I agree it's probably a ground problem, Is it coming from all the speakers or Just one? If it's coming from all then it may be a radio ground issue if it's coming from one then possibly one of the amps my need a new ground. Hope this helps (This did fix my C4 but I just got a 04 C5 so no problems on the C5 yet)
Old Nov 10, 2004 | 04:22 PM
mikejaeggi's Avatar
mikejaeggi
I had a problem with every sound coming out of the Bose system. JK-I agree it sounds like a ground.
Old Nov 10, 2004 | 04:33 PM
marksr's Avatar
marksr
I think it comes from all speakers, but not 100% sure. So can anyone tell me where the ground for the radio is? I had a hard enough time finding a good ground for my radar detector.
This is a 2004 with 2,000 miles on it. I will take it to the dealer at 7,500 if I can't resolve the issue. This didn't happen until recently.
Old Nov 10, 2004 | 04:35 PM
NSTG8R's Avatar
NSTG8R
agreed, it's a ground issue. Happens with subwoofers too if they're not grounded properly.
Old Nov 10, 2004 | 05:11 PM
EatRice's Avatar
EatRice
Take it to the dealer..it is still under warranty. Since it is a factory system untouched it is most likely a faulty piece of electronics. Not likely that the factory ground came loose and if it did the products would not work at all...not cause a turn on thump. Either the output from the radio is bad or the input to the amp is bad. Either way just take it to the dealer and have them swap electronics till it is gone.
Old Nov 10, 2004 | 06:35 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Only "thunmp" my stock stereo had before I got a real one was the blown subwoofer ... came blown with the car.
To Stereo Power On THUMP
