Mirror help.
Old Nov 7, 2004 | 11:20 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Default Mirror help.
Can I use a mirror, like one found in a trailblazer with the autodimming feature, map lights, compass, and on-star.
I want the auto dim, lights and the compass to work.
Can the mirror be wired to my 00 vette with the normal mirror, like the 01 and up vette autodimming mirror can be wired to the older vettes.
Old Nov 7, 2004 | 11:27 AM
NSTG8R's Avatar
NSTG8R
Here's a link, I believe these wire right up.
http://forums.corvetteforum.com/show...Mirror+Compass
http://www.sportsimportsltd.com/aumiwiho.html
Old Nov 7, 2004 | 11:30 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Here's what I did - http://www.c5forum.com/diy/electro_mirror.php
I have a '98 and everything works. It will not give you the compass feature like your Trailblzer. I have a compass in my 98 Blazer - and I can easily live without it. The Corvette mirror has the amber "night light" that I don't think the Trailblazer has - and the map lights also act as courtesy lights since there is no overhead light on a Vette.
It was actually pretty easy and these directions are very complete and accurate.
Personally - I'd rather have an O.E.M. Corvette mirror. As far as pricing - I went to Fichtner and got a great deal!
Old Nov 7, 2004 | 11:31 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
I believe that some members have had luck splicing in the new wire harness but it is not a direct drop in.
Paul
Old Nov 7, 2004 | 11:45 AM
screw991le's Avatar
screw991le
Ok, So it can be done? I am looking at an 05' impala mirror with the map light and compass, so, i am asking are the important wire colors the same, so the autodimm and lights will work?
To Mirror help.
