x pipe
Old Nov 10, 2004 | 09:16 AM
steves red vette's Avatar
steves red vette
Default x pipe
i just put on z06 exhaust and was wondering if an x pipe would help and how much h.p. also will the x pipe pass smog. thanks
Old Nov 10, 2004 | 09:25 AM
bozo4onion's Avatar
bozo4onion
I have Z06Ti and wonder about the dif. in sound after Xing.
Old Nov 10, 2004 | 09:44 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
I ran for awhile with a Magnaflow X-pipe and stock (non-Z06) exhaust. The only audible effect was a slightly deeper tone when accellerating. Any hp improvement is negligible.
Smogging should not be an issue, since it is a passive part (after the cats) and not visible unless the car is on a lift.
Old Nov 10, 2004 | 10:18 AM
mdhmi's Avatar
mdhmi
Originally Posted by BW1
... Any hp improvement is negligible ...
You might see 2-5 hp.. If you prefer not to listen to gurgling on deceleration then go with an x-pipe.
Mark
Old Nov 10, 2004 | 10:35 AM
jrose7004's Avatar
jrose7004
Since the X-Pipe is after the cats then its not a problem for passing the smog test!
Old Nov 10, 2004 | 10:58 AM
Flintstone's Avatar
Flintstone
The X will mellow any exhaust above what you hear with the factory h-pipe. You put an x-pipe in more for better sound than hp.
My B&B Bullets were LOUD with my Magna x-pipe. When I installed the Bullets on a friends car with stock H-pipe, the noise was a notch short of deafening
F
Old Nov 10, 2004 | 11:11 AM
Thunder7's Avatar
Thunder7
So thei Bullets with an X-PIPE were even louder than with the H....interesting.....how was the difference in "burbling"...
Old Nov 10, 2004 | 12:55 PM
The X-pipe should not present any problems with a smog check. It may make the exhaust sound a little deeper, but really no performance gain that I have noticed.
Old Nov 10, 2004 | 01:16 PM
Flintstone's Avatar
Flintstone
Nope, other way around. Also, with x-pipe most if not all the burbling was gone.
Old Nov 10, 2004 | 01:27 PM
Thunder7's Avatar
Thunder7
Ah, OK...shew....I have the bullets (and love them), but don't want it to be any louder, but have been looking at an X-Pipe to smooth it out...
To x pipe
