Help! Horn stuck
Old Nov 10, 2004 | 08:41 PM
1vette98's Avatar
1vette98
Default Help! Horn stuck
Has anybody ever had a horh start blowing and won't cut off? I was backing out of the garage and the horn started blowing and won't stop. I had to disconnect the battery to silence it. Any suggestions would be appreciated.
Old Nov 10, 2004 | 08:49 PM
OOBlackconvert's Avatar
OOBlackconvert
Pull the horn fuse while looking for a short. Or just drive around and wave alot
Old Nov 10, 2004 | 08:50 PM
1vette98's Avatar
1vette98
I forgot to mention, I had the column lock bypass recall done today. Think that might have anything to do with this?
Old Nov 10, 2004 | 08:57 PM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
a coincidence beyond proportion to me...
Old Nov 10, 2004 | 09:27 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Was it beeping or on steady?? Please let us know
BC
Old Nov 10, 2004 | 09:46 PM
jimbee's Avatar
jimbee
Mine did the same thing, going straight it's ok, turn the wheel either way and the horn blows. Did you turn the wheel when it started?
Old Nov 10, 2004 | 09:53 PM
SmashF15C's Avatar
SmashF15C
Default Horn
I had the horn problem also - went off while parked one time, did not stop until the horn shorted itself and blew the fuse.
I posted here when it happened and one guy told me that the horns get dirty/wet and short out sometimes. My plan was to get a new horn and replace it, and see what happens.
I have not gotten around to it yet. Sounds like a plausible solution to me. Let me know if it works before I get to it in ~Jan probably.
Smash
Old Nov 11, 2004 | 01:34 AM
1vette98's Avatar
1vette98
I was backung out of the garage, wheels were turned to right at first, but straight when the horn started. It was continous. I shut the engine off and restarted, thinking it may have been something with the alarm. No help. Calling the Dealer first thing tomorrow.
Old Nov 11, 2004 | 05:39 PM
JC in XTC5's Avatar
JC in XTC5
If it's a stuck switch in the steering wheel, the dealer will tell you the airbag assembly will need to be replaced (about $700). The horn switches are imbedded in the wheel airbag pad assembly and not serviceable.
But it is possible that your problem is due to a short somewhere down the circuit - maybe after the CLB install the wiring harness wasn't routed properly and got clipped.
Good luck.
Old Nov 11, 2004 | 08:21 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Its the body control Mod, happen to me before, have it checked.
To Help! Horn stuck
