Transporting C5s - tie down strategies
Old Nov 10, 2004 | 11:35 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Default Transporting C5s - tie down strategies
A member of our local club plans to retire soon, and plans on spending a lot of time RVing around, and will be trailering his C5 in an enclosed trailer as their run around vehicle - gotta love his plans!!!
Anyway he told me that he was having trouble finding tie down straps that had hooks small enough to fit into the slots underneath. I know there are folks on the forum that must have some insight on what he needs - thoughts or suggestions?
Old Nov 11, 2004 | 02:11 AM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Well, ontop of using the slots under the car, the lady driving the tow truck also had soem straps wtih special spots for the wheels, and tightened down the straps which were enclosing the tires.
Old Nov 11, 2004 | 02:18 AM
NSTG8R's Avatar
NSTG8R
there are straps which you place on the tire and that straps the car down. I beleive you use those in conjunction with a tiedown on the rear suspension (this is used as a backup)
Old Nov 11, 2004 | 08:31 AM
iceburgh's Avatar
iceburgh
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05-'06-'07-'10
I use axel straps over the "A" arms...towed 13,000 miles last year never had a problem
http://www.autotiedowns.com/opentrailersystem.html
Old Nov 11, 2004 | 08:46 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Strapping the A-arms long term will cause wear on the A-arm bushings and cause allignment problems.. Maybe it would be best for your friend to have tow hooks welded to the underside of the car and then use ratchet type straps?
VR
Old Nov 11, 2004 | 10:16 AM
DE CHIEL's Avatar
DE CHIEL
T-Hooks From an towtruck supply place or Northern Tool $8.00 each
http://www.northerntool.com/webapp/w...=43572&R=43572
use race car tie downs also 5,000 lbs each $25.00 each need 4
http://www.northerntool.com/webapp/w...=21895&R=21895
Old Nov 11, 2004 | 11:34 AM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Essentially exactly what I use. I hook them to the trailer in two X's like this:
X
X
The tie down behind the LF wheel goes forward under the car to the RF of the trailer. The tie down in front of the LR wheels goes aft to the RR corner of the trailer. Opposite on the other side.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Nov 11, 2004 | 03:24 PM
AU N EGL's Avatar
AU N EGL
<---- DE CHIEL is G/F nic at her house and puter
Tom
Old Nov 16, 2004 | 12:35 AM
Ls1Rat's Avatar
Ls1Rat
Hooking to the a-arms won't hurt a thing , but the straps over the tires set up works great.
Old Nov 16, 2004 | 12:58 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
Straps over tires is what they used to transport mine(closed container carrier) from Kerbecks in New Jersey to me here in Virginia...worked great...
Old Nov 16, 2004 | 02:26 AM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
I posted a thread asking the same question a couple of weeks ago.
I ended up using Subdrivers and a couple others suggestions
on using T-Hooks in the factory tie down slots under the car and crossing the straps in an X configuration to the front & back of trailer.
Works great and don't have to worry about any bushing or allignment problems over an extended period of time hauling car.
Here's a link where I bought my straps from. Great price and good selection of colors. They were delivered to my door in 3 days!
http://www.rjays.com/Rjays_tiedowns/tie-downs-01.htm
Here's the link where I bought my T-Hooks
http://www.awdirect.com/awdirect/cat...kon=subsection
Here's a pic of the T-Hook
Old Nov 16, 2004 | 08:52 AM
AU N EGL's Avatar
AU N EGL
IMHO use the t-hooks pictured above and the 5000 lbs straps in the X pattern is the safest and strongest way to secure your baby to the trailer.
Old Nov 16, 2004 | 09:18 AM
ptdrummer54
CI 5-6-7-8 Veteran
NCM Ambassador
Thanks everyone - these suggestions are very helpful...
Old Nov 16, 2004 | 09:53 AM
Corpsvette's Avatar
Corpsvette
Veteran: Marine Corps
THis past March I hauled my mistress from NC to Cali (4000 miles when done) using the T hooks everyone has mentioned and criss crossing my tie downs. On two occassions I was forced to lock up the brakes and the car never moved a bit on the trailer. NOw the Avy and trailer did a little sliding. Whew that is scarry. Good luck.
Jim K.
Old Nov 16, 2004 | 10:50 AM
vetterdstr's Avatar
vetterdstr
I think you are getting good advice from the members who actually trailer a vette long distances. I have found that the T-hooks are a great setup, although tough to install on an enclosed trailer. Best of luck to you on whatever you decide.
VR
Old Nov 16, 2004 | 11:52 PM
Ls1Rat's Avatar
Ls1Rat
I like those !!! If I ever trailer my C5 , I'll buy 'em !
To Transporting C5s - tie down strategies
