Annoying DIC message
Old Nov 11, 2004 | 07:28 PM
silverminevette's Avatar
silverminevette
Cruise-In V Veteran
Cruise-In VII Veteran
St. Jude Donor '03-'04-'05-'06
Default Annoying DIC message
My DIC keeps alerting "Low washer fluid" since picking it up from the body shop yesterday. The tank is full . The left fender and wheelwell and front fascia were replaced and I'm wondering if anything they did could be causing the problem. When I first picked it up the "coolant level" alert was showing as well but that has ceased. I have reset the alert each time but it continues. Not terribly serious in the grand scheme of things but ANNOYING! Anyone have any suggestions?
Old Nov 11, 2004 | 07:33 PM
LoneStarFRC's Avatar
LoneStarFRC
It could be that these two tanks are not level. There is an easy procedure for checking and correcting but I'm at work right now and don't have my shop manual handy.
Bill Curlee: You out there?
Old Nov 11, 2004 | 07:37 PM
HummelS's Avatar
HummelS
Could be they failed to reconnect the fluid level switch in the coolant tank - either that or the switch itself is stuck. It connects at the back of the tank.
Old Nov 11, 2004 | 07:56 PM
I'd check the sensor at the back of the tank (towards the fire wall on the bottom). Could be loose, disconnected or going bad.
Old Nov 11, 2004 | 08:01 PM
silverminevette
Cruise-In V Veteran
This is what the connection looks like at the rear of the tank. Everything feels tightly connected.
Old Nov 11, 2004 | 08:06 PM
USA-VET's Avatar
USA-VET
The sensor is not orientated the right way, the little black tab should be on the bottom. Unplug it and turn it so the clip is on the bottom, there is a float sensor in there and it has to be that way, don’t ask how I know this!
Old Nov 11, 2004 | 08:10 PM
HummelS's Avatar
HummelS
Here's a diagram of the switch; sounds like it could be an orientation problem - you can see how it's supposed to be:
Old Nov 11, 2004 | 08:17 PM
silverminevette
Cruise-In V Veteran
Ok, I'm an idiot. I pulled out the plug - fluid spilled out. Where do I need to unplug it?
Okay. The white plug turns freely without pulling it out. I've reoriented the clip downward. Turned the car on, no alert so far but it didn't always come on immediately so I don't know if it's fixed or not.
Old Nov 11, 2004 | 08:26 PM
USA-VET's Avatar
USA-VET
unclip the little black tab
then turn it!
this what it should look like from the top when you are done
Old Nov 11, 2004 | 08:33 PM
silverminevette
Cruise-In V Veteran
then turn it!
this what it should look like from the top when you are done!
I unclipped the tab. It only attaches to the white plug one way. The white plug turns freely without unclipping the tab and I have reoriented the clip downward. Can't see any other way to do this.
Old Nov 11, 2004 | 08:35 PM
USA-VET's Avatar
USA-VET
as long as the clip is down its good! now restart the car and you might have to reset the message and refill the tank!
Old Nov 11, 2004 | 08:38 PM
silverminevette
Cruise-In V Veteran
Sounds like it might be fixed. Thanks to all for your advice. The forum rocks!
Old Nov 11, 2004 | 10:01 PM
ALLEGRO's Avatar
ALLEGRO
See,,,, I this not a COOL place or not!
CF to the rescue AGAIN
Old Nov 11, 2004 | 10:11 PM
barkingowl's Avatar
barkingowl
Cruise-In IV Veteran
Cruise In V Veteran
Cruise-In VI Veteran
Old Nov 11, 2004 | 11:19 PM
USA-VET's Avatar
USA-VET
To Annoying DIC message
