Rusty Rotors.... HELP!
Old Nov 11, 2004 | 08:54 PM
C5Ken's Avatar
C5Ken
Default Rusty Rotors.... HELP!
I store my 2001 Vert for the winter & the rotors get rusty & pitted when the car is not driven for several months. Is there anything I can put on the roters to prevent rust while the car is in storage?
Old Nov 11, 2004 | 09:15 PM
yelloyello's Avatar
yelloyello
CI 6-7, 9-10 Veteran
I don't think so. You might think about having them turned in the spring
Old Nov 11, 2004 | 09:48 PM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
Don't worry about it... After you drive it for a few miles, it will go away.
You could try coating them in a little oil to prevent the rust if it really bothers you....
Old Nov 11, 2004 | 10:08 PM
jrose7004's Avatar
jrose7004
Theres something about oiling the brakes that doesn't seem right!
Old Nov 11, 2004 | 10:12 PM
Z0SLIK's Avatar
Z0SLIK
Old Nov 11, 2004 | 10:22 PM
cob206's Avatar
cob206
St. Jude Donor '05-'06-'07-'08
If it really bothers you, you could store the car in a Car Jacket. www.carbag.com Its a sealed bag that controls humidity. This is the first season mine will be in one, but I have several friends who have used these and they report the rotors are clean at the end of storage.
Old Nov 11, 2004 | 11:07 PM
fat bob's Avatar
fat bob
C5Ken, something to do that should help significantly is not wash the car without then driving it before storage. This helps a great deal. The car should not be stored without driving enough to heat the rotors if it has been washed. It might sound crazy but it does work.
Old Nov 11, 2004 | 11:31 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
After washing the car I always go around the block to dry out the brakes. Either that or they rust like crazy. If they are clean and shinny they shouldn't rust over the winter in a garage. At least mine don't. And I live on the wet coast. You could spray some WD-40 on them then clean them off in the spring with some lacquer thinner or gas and they should be fine. My .02
To Rusty Rotors.... HELP!
