If you haven't seen in some of my previous posts. It turns out the wheel hop broke the Diff case which in turn snapped the output shaft of the transmission.
I would like to thank Rodney <crashed 94> for all his help today, and say he orginally built the trans, and will now be building my diff and trans.
Nice pics. I remember having a bit of hop with my first Z06. Glad it never caused serious problems.
Good luck on the rebuild.
Not to suure about changes, i'm only running ~380rwhp, i see no huge need for a 500 dollar output shaft...Sadly i did not break the ring and pinion, although i'm tempted to buy 4.10's and just throw them in. It's all still in the air, anybody know the cheapest for 4.10's?
<edit: I am for sure going to be using a DTE brace
The output shaft shouldnt run $500...I dont think...
and 4.10 ring and pinion as I remember werent that high...
I just dont recommend that you buy a 4.10 dif complete...
...found too many bad parts in the ones Im aware of...
so if you can replace the case...the build out should be worth the change...
Thanks Stuart, it looks as though i'm shipping my whole drive line up to Rodney to let him work his magic yet again. I don't think i'm going to upgrade the gears, the upgraded output shaft runs about 500 bux, I'm going to replace with a stock cryo'd output shaft, and purchase the DTE brace as well. I don't have the traction or the power to snap a shaft, the case broke and sheerd the current shaft.
