Stan- KILLER?? I see an engine, I see grease, I see toes but then hope with all the pizza there... we can only hope you are hiding 6-pks under those t-shirts??
Just curious, was it some major wheel hop? Anything you can do to avoid the wheel hop? Different tires or something? Curious cause I wan to make sure I don't do the same thing. Man does that look expensive.
Well, no stock in pizza, but as for the wheel hop, I was running very low on gas, and that's the worst wheel hop i've ever had, soo...the gas probably played a little with it, I also should have probably launched a little harder to blow the tires into smoke, and of course tires and suspension have a lot to do with wheel hop as well!
