It sounds like a power window motor going out. I had the same thing with my 99 coupe. The passanger window would work sometimes, than not. Replaced the motor assembly, and no more problems.
Window works some time.. then quit !! Is there a fuse for the windows only ? Gotta love these little problems that pop-up !!!
Is this the passenger side?? Common problem if so. Does the window "click" and the lights dim when you hit the button?? Sometimes you can get by with slamming the door while holding the "down" button at the same time. Usually frees up in a few shuts. If not, could be a bad regulator or something in the circuit board in the door.
Actually could be many things...... so....... respond back with a little more explanation of the problem you're having.
ie..... drivers or passengers side not working, drivers or passengers side control not working, power lock does or doesn't work, window clicks but doesn't move, etc.
