problem with battery companion?
Old Nov 12, 2004 | 08:38 PM
brad6285's Avatar
brad6285
Default problem with battery companion?
i bought a battery companion (same as battery tender) from auto zone for my optima red top. its a 1.5 amp trickle charger and has 3 led lights: charging, charged, and trouble. i connected it up the other night and it was in the charging mode then i checked it the next day and the led light for trouble was lit up. i connected it to the side terminals shouls i have connected it to the top terminals on the optima. what else could be wrong? if the battery is fully charged it would switch to the charged led right? any suggestions? thanx
Old Nov 12, 2004 | 08:54 PM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
I had the samething with my battery tender stayed red for hours then i went to pull the plug out from the extension i had it pluged into and the darn thing turned green and has stayed green .But some of the people on the forum told me if the battery is fully charged it will go from red to green and nothing in between it just scared me because it stayed red for along time and the battery tender got really warm, but it seems to be ok now.
