Has anyone fabricated a hartop form a donor FRC top for a conv. i have a conv, and just got all the pieces from a z06, seems like an easy task but still cusrious if there is anything i should look out for.
I am using the front hradtware form a targa and plan on custom building rear attachment points, havent figured out yet how well the rear will seal ??
You have to graft the hardtop to your convertible hatch.The hardtop will not seal without doing this, a portion of the underside on the hardtop and a portion of the top on the convertible hatch must be cut away and then the two peices must be bonded together. When properly done this top is much better than a after market hardtop.
