born on date/build sheet
vin: 1G1YY32G8Y5112737
thanks!
lenny
The month and year that your car was built is printed on the sticker on the driver's door. If you own a coupe, pop the rear hatch and remove the right most storage cover. On the back of the storage cover is a sticker which has the month, day, year, and time that your car was built. I assume that the time is when the engine was first fired up. Can anybody confirm that?
thanks!
lenny
VEHICLE BUILD
Merchandising Model : 1YY67 -2000 CORVETTE CONVERTIBLE
Gross Vehicle Weight Rating : 1674 kg (3691 lb) Order Number : BZCTJ2
Build Date : 11/17/1999 Build Plant : 1Y5Y - BOWLING GREEN
OPTION CODES
AAB - MEMORY PACKAGE AG2 - SIX-WAY POWER PASSENGER SEAT
AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES
BGR - BOWLING GREEN PLANT B34 - COLOR-KEYED FRONT FLOOR MATS, CARPETED INSERTS
CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE C05 - CONVERTIBLE FOLDING ROOF
DL5 - ROADSIDE SERVICE INFORMATION DECAL DL8 - HEATED REARVIEW MIRRORS
FE3 - SPORT SUSPENSION FE9 - FEDERAL EMISSIONS
GU6 - REAR AXLE 3.42 RATIO IL3 - TRIM INTERIOR DESIGN-AQ9
JL4 - ACTIVE HANDLING SYSTEM JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM
K63 - 110 AMP GENERATOR LS1 - 5.7L LITER SFI, V8
MM6 - 6-SPEED MANUAL TRANSMISSION MN6 - 6-SPEED MANUAL TRANSMISSION
NF2 - FEDERAL EMISSION SYSTEM, TIER 1 NK4 - LEATHER WRAPPED STEERING WHEEL
N37 - STEERING COLUMN - POWER TELESCOPING & MANUAL TILT QF5 - POLISHED ALUMINUM WHEEL
R8C - CORVETTE MUSEUM DELIVERY T82 - TWILIGHT SENTINEL
T96 - FOG LAMPS UN0 - AM/FM STEREO W/CD PLAYER
UV6 - HEAD UP DISPLAY UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM
U1S - COMPACT 12 DISC CHANGER, REMOTE U52 - ELECTRONIC INSTRUMENTATION
U75 - POWER RADIO ANTENNA VM3 - CONSUMER INFORMATION LABEL
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA XGG - FRONT TIRE-P245/45ZR17 BW SBR
YGH - REAR TIRE-P275/40ZR18 BW SBR Z51 - PERFORMANCE HANDLING PACKAGE
1SA - OPTION PACKAGE - BASE 16T - TOP-WHITE
23U - NASSAU BLUE METALLIC 92I - MED GRAY INTERIOR TRIM
923 - LT GRAY LEATHER TRIMMED SEATING SURFACE
Merchandising Model : 1YY67 -2004 CORVETTE CONVERTIBLE
Gross Vehicle Weight Rating : 1661 kg (3663 lb) Order Number : GMQSH8
Build Date : 10/08/2003 Build Plant : 145Y
OPTION CODES
AAB - MEMORY PACKAGE AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM
AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES BGR - BOWLING GREEN PLANT
B84 - BODY SIDE MOLDINGS CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE
C05 - CONVERTIBLE FOLDING ROOF DD0 - ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR
DD8 - OSRV DL5 - ROADSIDE SERVICE INFORMATION DECAL
FE1 - SUSPENSION SYSTEM-SOFT RIDE FE9 - 50-STATE EMISSIONS
JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM K63 - 110 AMP GENERATOR
LS1 - 5.7L LITER SFI V8 - 350HP MM6 - 6-SPEED MANUAL TRANSMISSION
MN6 - 6-SPEED MANUAL TRANSMISSION NK4 - LEATHER WRAPPED STEERING WHEEL
NT9 - FED EMIS SYS, TIER 2 PHASE-OUT N37 - STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN
QF5 - HIGH POLISHED ALUMINUM WHEELS R9U - GM ACCESS - AUTOBOOK IDENTIFIER
SLM - STOCK ORDERS T82 - TWILIGHT SENTINEL
UN0 - AM/FM STEREO W/CD PLAYER UV6 - HEAD UP DISPLAY
UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM U1S - CD 12 DISC CHANGER, REMOTE
U52 - ELECTRONIC INSTRUMENTATION U75 - POWER RADIO ANTENNA
VDC - VEHICLE INFORMATION CD VM3 - CONSUMER INFORMATION LABEL
YGH - REAR TIRE-P275/40ZR18 BW SBR 1SB - PREFERRED EQUIPMENT GROUP * MEMORY PACKAGE * TWILIGHT SENTINEL * ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR * HEAD UP DISPLAY * STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN
1SZ - PREFERRED EQUIPMENT SAVINGS 19I - BLACK INTERIOR TRIM
193 - BLACK LEATHER TRIM SEATING 41T - T0P-BLACK
67U - MACHINE SILVER
Nice car Mr. CASERTA
with a date and time which is BEFORE my BOD. It does reference my
interior color however.
VEHICLE INFORMATION
Merchandising Model : 1YY67 -1998 CORVETTE CONVERTIBLE Warranty Start Date : 04/24/1998
BARS Order Type : 60 - RETAIL - SOLD
Delivering Dealer : HEISER CHEVROLET, INC.
10200 W ARTHUR AVE
WEST ALLIS , WI 53227-2005
(414) 327-2300
VEHICLE BUILD
Gross Vehicle Weight Rating : 1696 kg (3740 lb) Order Number : 910A8Y
Build Date : 04/16/1998 Build Plant : 1W5Y - BOWLING GREEN
OPTION CODES
AAB - MEMORY PACKAGE AG2 - SIX-WAY PASSENGER POWER SEAT
AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM AQ9 - ADJUSTABLE SPORT LEATHER BUCKET
FE1 - SUSPENSION SYSTEM-SOFT RIDE FE9 - FEDERAL EMISSIONS
F45 - CONTINUOUSLY VARIABLE REAL TIME DAMPING G90 - REAR AXLE-3.15 RATIO
G92 - PERFORMANCE AXLE RATIO IL3 - TRIM INTERIOR DESIGN-AQ9
JAG - BRAKE PROVISIONS ABS LOCATION JL4 - ACTIVE HANDLING SYSTEM
JL9 - 4-WHEEL ANTI-LOCK BRAKE SYSTEM K63 - 110 AMP GENERATOR
LS1 - 5.7L LITER SFI, V8 MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE
M30 - 4 SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE NF2 - FEDERAL EMISSION SYSTEM, TIER 1
NK4 - LEATHER WRAPPED STEERING WHEEL QD4 - STYLED ALUMINUM WHEEL
R8T - PRELIMINARY INVOICE R9Z - POMS EXPEDITE - SOLD ORDERS
UZ6 - QUAD SPEAKER SYSTEM U52 - ELECTRONIC INSTRUMENTATION
V49 - LICENSE PLATE FRAME V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XGG - FRONT TIRE-P245/45ZR17 BW SBR YGH - REAR TIRE-P275/40ZR18 BW SBR
1AZ - SOLD ORDERS PROC OPTION 1SB - OPTION PACKAGE - BASE
11U - LT PEWTER METALLIC 67I - LIGHT OAK INTERIOR TRIM
67T - T0P-LIGHT OAK 673 - LIGHT OAK LEATHER
Merchandising Model : 1YY07 -2001 CORVETTE COUPE Warranty Start Date : 11/14/2000
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : HAMILTON CHEVROLET, INC.
5800 14 MILE RD
WARREN , MI 48092-3199
(586) 264-1400
VEHICLE BUILD
Gross Vehicle Weight Rating : 1678 kg (3700 lb) Order Number : CTHM03
Build Date : 11/06/2000 Build Plant : 115Y - BOWLING GREEN
OPTION CODES
C2L - DUAL REMOVABLE ROOF PANELS DD0 - ELECTROCHROMIC MIRRORS: ISRV & LH OSRV
D42 - REAR COMPARTMENT LUGGAGE SHADE AND PARCEL NET FE1 - SUSPENSION SYSTEM-SOFT RIDE
FE9 - 50-STATE LOW EMISSION VEHICLE GU2 - REAR AXLE 2.73 RATIO
IL3 - TRIM INTERIOR DESIGN-AQ9 JL4 - ACTIVE HANDLING SYSTEM
LS1 - 5.7L LITER SFI V8 - 350HP MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE
M30 - 4-SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE NF7 - FEDERAL EMISSION SYSTEM NLEV
NK4 - LEATHER WRAPPED STEERING WHEEL N37 - STEERING COLUMN - POWER TELESCOPING & MANUAL TILT
QG1 - PAINTED ALUMINUM WHEEL T82 - TWILIGHT SENTINEL
UV6 - HEAD UP DISPLAY UV7 - WINDSHIELD ANTENNA
UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM U52 - ELECTRONIC INSTRUMENTATION
VM3 - CONSUMER INFORMATION LABEL V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
1AY - STOCK ORDERS PROC OPTION 1SC - CORVETTE COUPE PREFERRED EQUIPMENT GROUP 2: * DUAL ZONE AIR CONDITIONING * FOG LAMPS * LUGGAGE SHADE AND PARCEL NET * MEMORY PACKAGE * ADJUSTABLE SPORT BUCKET SEAT * POWER PASSENGER SEAT * TWILIGHT SENTINEL * ELECTROCHROMIC MIRRORS: ISRV & LH OSRV * HEAD UP DISPLAY * STEERING: POWER TELESCOPING & MANUAL TILT STEERING COLUMN
19I - BLACK INTERIOR TRIM 193 - BLACK LEATHER TRIM SEATING
41U - BLACK
