First modifications
Old Nov 14, 2004 | 03:10 PM
Rock0324's Avatar
Rock0324
Default First modifications
I have a stock 98 convertible with 53000 miles. I want to do some mods for improved performance. What should I be looking at? Also, should I have the work done at the Chevy dealer or a specialty "Vettech" type of shop?
Old Nov 14, 2004 | 03:16 PM
yelloyello's Avatar
yelloyello
CI 6-7, 9-10 Veteran
This subject seems to come up almost daily. Airbox, headers, heads and cam are for starters. DO NOT under ANY circumstances let the stealership do any of your mods. Also, you might want to look for a dealership that is 'mod friendly'. Good luck
Old Nov 14, 2004 | 03:20 PM
vetterlatethannever's Avatar
vetterlatethannever
First, and probably most importantly, you need to decide what you are willing to spend. Mods for our cars range in price from free (zip tie mod, cut outs on filter cover) to upwards of 20k (twin turbo and 427 setups). I went in looking to just do an underdrive pulley for about 500 and ended up with about 10 times as much.......The result was phenomenal though, the car is a blast to drive and acceleration is sickening!!!, and I love it!!!! Give us an idea of what you are looking for and we will gladly help you with the fever!
Old Nov 14, 2004 | 03:32 PM
jrose7004's Avatar
jrose7004
I would have to 100% agree with this answer!
Old Nov 14, 2004 | 04:00 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
***Beware of Mod Fever... it grips us all in its lethal claws... kiss your retirement, pension and your kids college fund goodbye once Mod Fever get a hold of you...
You have been warned..
EG
BTW, Wax = 9rwhp
Old Nov 14, 2004 | 05:46 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
First you get some mufflers that are the size of a small beer keg and stick them on the end of your tailpipe. That's good for 20 hp. Then you get a large red "R" decal and put it on the back. Two if possible. They're good for at least 5 hp each. Then get the famous underhood seal that will add 5 hp to your car and go out looking for Z06's!
Old Nov 14, 2004 | 07:34 PM
T's's Avatar
T's
Cruise-In VII Veteran
St. Jude Donor '06-'07-'08
hood seal
Don't for get splash guards !
Old Nov 14, 2004 | 07:37 PM
Lensboard's Avatar
Lensboard
There really should be a "mod faq", or something similar since we all see these posts almost every day. I for one asked the very same questions, and was given sound advice from the gracious members here.
Old Nov 14, 2004 | 07:47 PM
OrionVettes's Avatar
OrionVettes
Beware! Mods are addictive! My Wife says I'm working on Christmas 2010
Old Nov 14, 2004 | 08:09 PM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
Generally an air intake and an exhaust w/ x-pipe is a good place to start. You need to consider where you want to end up before you start so that you don't mod and undo too often.
It's all good .... go for it!!!
Old Nov 14, 2004 | 10:58 PM
Dave68's Avatar
Dave68
Check my sig for mods and the resulting horsepower increases. My total cost has been about $800.
Old Nov 14, 2004 | 11:30 PM
vetterlatethannever
Oh, by the way, for a good looking mod you should check out Dave68's shift *****. Those are sahweet!! Although I think the HP gains he claims from them are overrated!!!......
To First modifications
