OUCH - aiming headlights
Old Nov 14, 2004 | 11:58 PM
Ag_bullet's Avatar
Ag_bullet
Default OUCH - aiming headlights
Ok. I might have brought this on myself but here goes.
Just installed the Rev Extreme HID's today and went out tonight to aim them. Pulled out the torx #15 to adjust the hidden up/down turning thing and sure as crap the darn thing stripped instead of turning! Now I can't adjust in the vertical direction for the headlight on the driver side. It's a little low now. I'd like it a bit higher.
Any suggestions?
Is there a tool to fit over the outside of that turning thing?
Old Nov 15, 2004 | 12:27 AM
gmosley's Avatar
gmosley
Default tool
i think its called a reverse torx or inverted torx socket try your local sears
Old Nov 15, 2004 | 12:09 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
7mm rachet will do the trick ...
Also, I would check to make sure the bulb is seated properly. If you're having to turn the adjustment enough to strip the torx screw, there might be a problem with how the bulb is "seated". I know this because I had the same thing happen ... turned out to be the bulb.
Old Nov 16, 2004 | 12:21 AM
Ag_bullet's Avatar
Ag_bullet
Default problem solved
Here's to another problem solved by the good men and women of this forum.
The bulb was seated crooked and I did pick up a set of the torx-bolt ratchets to make fine adjustments.
To OUCH - aiming headlights
