Blackwing/Hood seal
Old Nov 15, 2004 | 10:02 AM
Fastgenious's Avatar
Fastgenious
Default Blackwing/Hood seal
When I install my Blackwing on my 04 Z06, should I also install a hood seal on the front hood area? I have heard about sealing up the front hood area because of water draining down by the filter. Should I leave the seal off so that I get a little air flow to the Blackwing through the space between the front end and the gap in the hood? I know the the gap is small but it does let some air flow in and out through the hood. What do you people think? Thanks...
Old Nov 15, 2004 | 10:19 AM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
Just a subjective opinion here ... but I think the hood seal is a good thing for the Blackwing. It's pretty much exposed to the elements, and water coming in would saturate it. I went ahead and installed one when I put my Blackwing in, just to be safe. There should be plenty of air available otherwise.
You might want to consider just buying some quarter-round shaped weather stripping instead of spending $14 on what they sell as a hood seal. It's soft rubber and hollow in the middle, and should be readily available in a hardwared store.
Old Nov 15, 2004 | 10:26 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
I did the "highperformance" hood seal too I was worried about water finding it's way down to the Blackwing during washing and driving. A side benefit is that my engine bay stays a lot cleaner with it in place. I believe someone said Autopalace carries this trim gasket material and for like $12.00 you get enough to do 3 cars.
Paul
Old Nov 15, 2004 | 10:35 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I've got a Blackwing and a hood seal too. I don't know if there was any benefit other than it keeps the engine a little cleaner and the water out.
It couldn't hurt!
Old Nov 15, 2004 | 10:41 AM
14U2ENV's Avatar
14U2ENV
From: Lino Lakes, MN _________________________ I Figured out how to do this!
St. Jude Donor '04-'05-'06
It couldn't hurt!
As for the HP increase.....Well.....
It does help keeping the water off of the Blackwing though.
Old Nov 15, 2004 | 12:39 PM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
Old Nov 15, 2004 | 01:15 PM
I installed the hood seal on mine and run the Blackwing. Sure helps keep the dirt out and water keeps off the filter. The seal can be made by buying a piece of automotive weatherstripping at a hardware store. Pretty cheap.
Old Nov 15, 2004 | 01:17 PM
pewter99's Avatar
pewter99
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
I got it for the dirt/water thing...works fine
Old Nov 15, 2004 | 01:22 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Blackwing & hood seal = does the business
HP Increase? Who cares, it looks
Same with the 2 tip Stingers...
Old Nov 15, 2004 | 01:33 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Talon90 is correct! I got a package at AutoZone and it did my 98 and 02 ZO6 with about 18" left over!
I cut the air box on my 98 Coupe for more air flow! The water runs right in on the filter! Before the hood seal install it rained one night and froze later that morning! The K&N filter media was frozen solid and the car would hardly run other than IDLE!!!
The hood seal will prevent that and your engine and engine bay will stay MUCH cleaner!!!!
Here is what the seal looks like!
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
BC
Old Nov 15, 2004 | 01:42 PM
JOHN MOORE's Avatar
JOHN MOORE
just installed a blackwing two weeks ago...installed a hood seal at the same time...does seem to keep things a little cleaner inside the engine compartment...notice that many people have a problem with the adhesive on the seal...mine's holding ok for now...will re-attach it with some 3m when comes loose...
Old Nov 15, 2004 | 03:37 PM
MRCoupe2002's Avatar
MRCoupe2002
I have a Blackwing and put in the hood seal because I found that the water coming in was washing out the filter oil slowly but surely. That being said, I also noticed that because of the hood seal, my intake air temperatures run much higher, so much so that sometimes the PCM starts pulling timing (reducing HP). This was especially apparent during my last trip to the track which was on a 85+ degree day. My IAT was sometimes as high as 158 degrees because the engine was pulling more air from the engine compartment than from outside during idle. I have since removed the head seal and am looking for some other possible strategies for getting more fresh air to the filter, but still protecting the filter from water.
Old Nov 16, 2004 | 10:26 AM
Fastgenious
It sounds like the hood seal is important to have installed too keep water off of the filter. I never "track" the Z so I should be fine during the hot summer months. Thanks...
Old Nov 16, 2004 | 11:06 AM
jrose7004's Avatar
jrose7004
I did my air intake and hood seal at the same time. Mostly because I didn't want water to cascade down on the intake!
To Blackwing/Hood seal
