[Z06] DIC Codes
Old Nov 15, 2004 | 03:46 PM
l2vette's Avatar
l2vette
Default DIC Codes
The check engine light on my dash came on out of the blue! So I ran the DIC diagnostics and the code came up "10-PCM 1 code". I cleared the code by pushing reset, but how do you actually get the code number from the diagnostics test?
BTW, I have a 2004 Z16. thanks.
Old Nov 15, 2004 | 04:28 PM
t56gen3's Avatar
t56gen3
The DIC will give you the full code, don't remember which key you have to press off the top of my head. Maybe you just let it scroll through them all the first go-round before you get to manually sift. Been too long.
Old Nov 15, 2004 | 04:46 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
http://www.stengel.net/diccodes.htm
This should help........
Bob
Old Nov 15, 2004 | 05:29 PM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
You have to be in manual diagnostics. Manual mode will be entered after automatic mode ends and it can also be entered during the automatic sequence by pressing any button except "E/M".
When in manual diagnostics select a module by pressing the options button to go forward or the trip button to go back. Once a module is selected the DTC count for that module is displayed. Press gauges and fuel to scroll back and forth through the DTCs for the current module.
Old Nov 15, 2004 | 09:16 PM
l2vette's Avatar
l2vette
When in manual diagnostics select a module by pressing the options button to go forward or the trip button to go back. Once a module is selected the DTC is displayed. If more than one DTC is present for a particular module press gages to display the next DTC or fuel to display the prior DTC.
That's where i was, in manual mode and only got the readout as stated. I would like to know the actual problem code number.
Old Nov 16, 2004 | 12:47 AM
RussBt's Avatar
RussBt
You did not go into the individual modules.
Old Nov 16, 2004 | 12:55 AM
RussBt's Avatar
RussBt
You did not go into the individual modules. Read my last post again.
When in manual diagnostics select a module by pressing the options button to go forward or the trip button to go back. Once a module is selected the DTC is displayed. If more than one DTC is present for a particular module press gauges to display the next DTC or fuel to display the prior DTC.
Old Nov 16, 2004 | 01:05 AM
RussBt's Avatar
RussBt
You have to use the fuel and gauges buttons to read the codes listed under each module.
Old Nov 16, 2004 | 01:12 AM
RussBt's Avatar
RussBt
You have to use the fuel and gauges buttons to read the codes listed under each module. I updated my last post in an effort to make it clearer.
Old Nov 16, 2004 | 03:37 PM
l2vette's Avatar
l2vette
So that I understand, once you are in the manual mode and in the module you want, by pressing the fuel and guages buttons the DIC will display the problem code number?
Old Nov 16, 2004 | 05:34 PM
RussBt's Avatar
RussBt
Yes.
Old Nov 16, 2004 | 05:46 PM
l2vette's Avatar
l2vette
Yes.
Thanks!
To DIC Codes
