Dynamat vs. Frost King
We have a GM engineer who used scientific data to compare the different methods of sound insulating the interior of a Corvette. His recommendations were based on cost, effectiveness and intangibles (such as tar smell). As a result of that six week evaluation, he has provided us with an economical way of substantially reducing road noise in a C5.
On the other hand, we have a couple of people who have subjective opinions on the effectiveness of a product they spent hundreds of dollars on. There's no data to back up any claims of greater effectiveness. We know that Dynamat will produce a tar smell at higher temperatures and it costs six times as much. Just what am I missing here? Why the hell would anyone go the Dynamat route?
Just my .02 cents.
I found Evil's comments very informative. The day before this thread was posted, I had ordered some dynamat.
Based on the info in this thread, I plan to do an oven test of dynamat and smell the stuff for myself before putting it in.
From what I read the frost king is not as effective as Crazy's in reducing the tunnel heat, so I will probably try out Mike's suggestion of Reflectix.
I tried to get color coordinated latched to match the rugs in the trunk hatch area...installed in the C5,instead of the all black ones.,, ofcourse my car is the only car in the world with color coordinated latches, that came off the GM mold designed for this purpose. the cost would have added 1.5 cent to each latch. It was turned down for cost reasons..
Based on the info in this thread, I plan to do an oven test of dynamat and smell the stuff for myself before putting it in. was it based on this information or my response to your private message, and a specific course of action I gave you regarding your specific situation. Does 150F in your oven for 6 hours ring a bell?
If it makes you feel better I can post my question and your response over PM.The stuff about GM designing the insulation in the first place was a joke, hence
We sell the precut insulation kits for the C5 front and rear, the material is similar to FK but thinner and more dense with foil on both sides which makes is more heat rejecting and able to be used on the console area without problems. I have riden in a C5 Coupe that had the Frost King just recently and the sound reduction IMHO is the same as far as I can tell except for maybe a little more noise due to the console area not being covered. I did not have the decibel meter with me for that ride, but I have since done a test with a Radio Shack meter on a Coupe that I did the install on showing an average of 11db sound level reduction at 55 mph. Our kits will save you the time of spening the whole day JUST CUTTING the pieces. We also include FULL instruction on disassembly and what tools are needed.
I'm going to offer the kits at $200 shipped, which is our holiday sale price (before the sale starts!) to you anyone interested from the forum. We had an intro-sale a month or so ago that sold like mad and have been selling them at the regular price of $250 shipped since with great sales #'s. Feel free to contact me with anything else you'd like to know and be sure to check out the website WWW.EXOTICVETTE.COM (you can click on my sig) for info, I try to update as much as I can on the site, still learning the whole web-design thing.
Dyna-mat is good stuff, to do a whole car, as you can see will run you over $200 and that's for a couple boxes of uncut material. Plus, I must tell you, the heat reduction from this stuff simply is AWESOME. I don't claim to be the EXPERT in noise reduction, I just know what works and that our product, while it may cost a little more than buying rolls of Frost King, will save you a lot of time and headache if you plan on doing it yourself AND give you results that the wife will be happy with on those Cruises with her
Dan
The Frost King is very thin, only 1/8” in thickness. I wonder I should put two layers instead. Would that be overkill? Also, I wonder I should buy a roll of Reflectix for the tunnel area.
If the main propose of 1/8” Frost King self adhesive duct insulator is for noise/vibration damping purpose, one layer should serve the purpose. Two layers should be better in theory but the effect would not be doubled.
I have installed a 1/8” stainless steel and ceramic coated tunnel plate several months ago. The heat from the tunnel area seems not a problem anymore. For the Reflectix, it is superior to the 1/8” Frost King in heat reduction. However, because it does not have the self adhesive layer, it may not do a good job in noise/vibration damping as Frost King. Please comment.
To fix that problem, I cut out the areas on the bubble wrap where the seat touched the carpet and all is well!
I also installed the bubble wrap on top of the tunnel under the console! It made a major reduction in heat!
BC
I recently added frost king to the entire interior of my 00 FRC and the ease of install and the results were equal to the dmat without the smell and mess.It was like a puzzel cutting all the pieces to fit and overlap the seams slightly but after taking my time and doing it right,the results are undenyable. In addition , I removed the rear wheelwells and coated them with a spray on sound deadining coating from duplicolor on the top side.The wheelwells remained flexible for install and the results were well worth it.For the huge diff in price and the smell factor,Frost king for me!!!
