Leaky Rear End question
Old Nov 16, 2004 | 03:48 AM
Swimmer's Avatar
Swimmer
Default Leaky Rear End question
I took my Vette to the dealership about 6 months and 1000 miles ago to fix a leaky rearend. It was due to a gasket leak on the left side of the diff. My car was not under warranty and it cost about $400 to fix. Now it is doing the same thing. Should the dealer fix it for free if it is the same problem?
The car is a 2001 Z06 and it only has about 9000 miles on it.
Old Nov 16, 2004 | 04:16 AM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
I have the same problem with mine leaking on the left side of differential housing.
A local shop who specializes in vettes quoted me $100 to replace gasket.
I would think the dealership that did the repair on yours would be responsible for it, at no charge, since it has only been a few months and very little miles.
Old Nov 16, 2004 | 07:13 AM
MITCH's Avatar
MITCH
Default repair
the repair is covered from gm for 1 year 12.000 miles.
mitch
Old Nov 16, 2004 | 07:27 AM
Patches's Avatar
Patches
Absolutely, they should fix it at no charge. Sounds like they may have not used the anaerobic sealant to help prevent future leaks. Also, make sure they are using the latest seal design.
Old Nov 16, 2004 | 01:15 PM
I would say yes, they should repair it free of charge. Obviously they did not do something right. Good luck.
Old Nov 16, 2004 | 01:38 PM
n2spd's Avatar
n2spd
I had mine replaced twice. The first time they did not use the sealant or the new gasket. Shops around here charge $500. to replace the seal.
Old Nov 16, 2004 | 02:18 PM
mad99c5's Avatar
mad99c5
Had mine done in july and I got GM to pay 100% of the job.
Old Nov 16, 2004 | 04:38 PM
Z0SLIK's Avatar
Z0SLIK
Should be free!! Took two trips to get mine fixed!!
Old Nov 16, 2004 | 05:53 PM
budmont's Avatar
budmont
From: hamilton nj "Life's tough......It's even tougher if you're stupid."-John Wayne
My 99 had a leak on the right side. I looked like the output shaft seal was leaking so I replaced it. Still leaked, found out that there is a small hole on top of the housing centered over the output shaft. In the hole is a metal plug, the plug leaked when the car was in motion. Cleaned it off with Brake Klean and sealed it with black RTV, work like a charm.
Old Nov 16, 2004 | 06:12 PM
Cirrus8's Avatar
Cirrus8
Default Leak at drivers side diff shaft seal.
Had mine done twice. First time they used the faulty seals and it leaked again. The second time they used the new seals and it has been leak free since early July 04 and 2000 miles.
The new seals part nbrs are: 88996703 and 89047953. These are the seals for the shaft and the cover plate.
The total cost was $74.88 parts and $145.96 labor. Total: $220.84
The repairs were paid for by my GMPP Major Guard plan since my 3yr/36,000 warranty had expired. The work was done by my delivering dealer and I was very satisfied with the work and the care that they took of my Corvette.
Old Nov 16, 2004 | 06:15 PM
VetteSiNz's Avatar
VetteSiNz
I had mine repaired once (dealer replace gasket and seal), I'm going back for the second time - it's leaking again.
Old Nov 16, 2004 | 07:56 PM
Swimmer's Avatar
Swimmer
Thanks everyone. I have an appointment next Tuesday. I will make sure they are aware of the new gaskets and the anaerobic sealant.
Old Nov 16, 2004 | 07:59 PM
00hotvette's Avatar
00hotvette
Q how did you know it was leaking (drive way) and was it a auto?
Old Nov 16, 2004 | 08:52 PM
fat bob's Avatar
fat bob
Swimmer, in addition to all the good information you have especially from Cirrus8, it might also help to make sure that your dealer is aware of the GM bulletin that pertains to this problem for all C5 Corvettes.
The GM number is 03-04-20-005- (Sep 12,2003)
I had mine fixed last month. Most of the repairs have involved the left side output shaft. Hope this helps you.
Bob
Old Nov 16, 2004 | 09:35 PM
00hotvette's Avatar
00hotvette
Does anyone have the bulletin?
Old Nov 17, 2004 | 10:31 AM
fat bob's Avatar
fat bob
00hotvette, I got the bulletin from Fichtner.
Bob
Old Nov 17, 2004 | 10:54 AM
VETFVER's Avatar
VETFVER
Mine was fixed using the new part numbers and has stayed fixed knock on wood.
Dan
Old Nov 17, 2004 | 10:59 AM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
Originally Posted by Swimmer
... to fix a leaky rearend.
I suppose you could try some Kaopectate ... it comes in liquid form ....
Old Nov 17, 2004 | 12:45 PM
v.vet's Z06's Avatar
v.vet's Z06
Had mine fixed last week....leak on the left side. So far with 200 more miles, no leak!
To Leaky Rear End question
