The bulb which was burnt out fell apart when I removed it. I have a new one and I can not figure out how to put it in. Is there something that clamps it in? I wouldn't thing you would need to be a PHD, but I need HELP!
The bulb has wire loops at both ends. Clip the top loop over the contact, pull the bulb down and then clip the bottom loop under the lower contact working from left to right. I hope this helps...
A couple of questions. Do you insert the bulb with the outside edge of the loop (so only one side of the loop enters first) towards the hood or the flat part (so both sides of the loop enter at the same time) toward the hood? Do you put one end of the bulb in first then press toward the tension to slide the other end in place and release the pressure to hold the bulb in?
Update: I figured it out. It goes in flat so both sides go in together. I placed the bottom of the bulb on the lower tab and pressed down against the tension and pushed the top of the bulb in until it felt tight.
Well, since this thread was resurrected, can anyone recommend a simple plug and play LED replacement to the original hood halogen bulb?
Dave at YellowVette04 has the whole story on the LED's, in fact that's how I found how to install the bulb I took out 3 years ago. His YouTube channel...
Replacing this bulb is a real pain and for some reason it is a real sensitive fit. Make sure you unplug the line to it...it is impossible to change if it is on.
Hahaha. If it was on he wouldn’t need to change it.
OK, enough of the not so hellpful answers being provided. This thread has served its purpose and the procedure to replace the light bulb has been described.
