How to replace under hood bulb
Old Nov 17, 2004 | 05:16 PM
CROWVETTE's Avatar
CROWVETTE
Default How to replace under hood bulb
The bulb which was burnt out fell apart when I removed it. I have a new one and I can not figure out how to put it in. Is there something that clamps it in? I wouldn't thing you would need to be a PHD, but I need HELP!
Old Nov 17, 2004 | 05:20 PM
Blue Lion's Avatar
Blue Lion
The bulb has a metal loop on each end and just slides in place. The metal pieces attached to the hood give a little and hold the bulb in place mainly by tension.
Old Nov 17, 2004 | 05:39 PM
C5naples's Avatar
C5naples
Old Nov 17, 2004 | 05:42 PM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
How many CF members does it take to screw in a lightbulb?
Old Nov 18, 2004 | 09:19 AM
vettenovice's Avatar
vettenovice
It all depends if screwing in a bulb can be classified as a MOD!
Old Nov 18, 2004 | 09:53 AM
roscoe118's Avatar
roscoe118
Does anyone have the P/N of this bulb?
Old Nov 18, 2004 | 10:37 AM
rwlc5's Avatar
rwlc5
Make sure that you unplug the light before reinstalling the bulb. If you do not unplug you will risk burning your fingers. The plug is located down near the passenger side headlight.
Old Nov 18, 2004 | 03:57 PM
sambarnett's Avatar
sambarnett
I have an extra bulb. Wanna trade something for it?
Old Nov 18, 2004 | 04:09 PM
Gib's Avatar
Gib
Replacing this bulb is a real pain and for some reason it is a real sensitive fit. Make sure you unplug the line to it...it is impossible to change if it is on.
Old Nov 18, 2004 | 04:12 PM
ALLEGRO's Avatar
ALLEGRO
I have some that give you 5 more rwhp!
Old Nov 18, 2004 | 05:36 PM
Dave1998's Avatar
Dave1998
Is this case, is the performance hood seal required so that no light escapes from under the hood ?
Old Nov 18, 2004 | 06:21 PM
C6 Strangebob's Avatar
C6 Strangebob
I just replaced mine and the part number is 9433040, list price $1.68 at the dealer.
Old Nov 18, 2004 | 06:27 PM
madeouttaglass
Senior Member
Cruise-In V Veteran
Do you think Tuan Le sells Piaas for that application?
Old Nov 18, 2004 | 06:29 PM
Blue Lion's Avatar
Blue Lion
I got mine at Pep Boys but make sure you get the right one as they don't allow returns on bulbs.
Old Aug 18, 2019 | 04:53 PM
zuburg's Avatar
zuburg
A couple of questions. Do you insert the bulb with the outside edge of the loop (so only one side of the loop enters first) towards the hood or the flat part (so both sides of the loop enter at the same time) toward the hood? Do you put one end of the bulb in first then press toward the tension to slide the other end in place and release the pressure to hold the bulb in?
Update: I figured it out. It goes in flat so both sides go in together. I placed the bottom of the bulb on the lower tab and pressed down against the tension and pushed the top of the bulb in until it felt tight.
Old Aug 18, 2019 | 11:55 PM
TinkersVet's Avatar
TinkersVet
don't forget the blinker fluid for it
Old Aug 19, 2019 | 12:37 AM
FYRARMS's Avatar
FYRARMS
15-year resurrection HAS to be a new record!
To How to replace under hood bulb
Old Aug 19, 2019 | 02:25 AM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
In 2005 they came up with a bulb that does not need any fluid.
Old Aug 19, 2019 | 09:12 AM
Kiddbats's Avatar
Kiddbats
Actually late model 2004 where the first to offer the fluidless blinkers. They are probably the only 2004 collector edition cars, I think only 30 where ever made.
Old Aug 19, 2019 | 09:56 AM
jjc508520's Avatar
jjc508520
I tried an LED and didn't like it.
Went back to OEM and it does get HOT!
And it flickers occasionally - the retention leaves a bit to be desired....
