DIC-Fuel Range problem
Old Nov 18, 2004 | 02:45 PM
WWK888's Avatar
WWK888
Default DIC-Fuel Range problem
I just noticed yesterday after filling up that my "range" was not correct. It usually goes to 278 or so but this time it was at like 54 and then it would start dropping slowly, even when I was sitting still in my garage. My gas gauge is still working correctly thank goodness. Anyone ever have the same problem? I hate to do it but I guess I have to go to the dealer as I am still under warranty.
Any comments would be appreciated.
Old Nov 18, 2004 | 02:50 PM
srchief100's Avatar
srchief100
Go to your MPG reading and try resetting, and then go for a short drive to give the computer time to "do some math" and then check the range when your Avg MPG levels off.
Old Nov 18, 2004 | 03:06 PM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Hey srcheif100...
Thought you'd left the forum not seeing your "stars" avatar for a while. That babyface...must be what they meant when they say it's a face "only a mother could love..."
Old Nov 18, 2004 | 03:32 PM
srchief100's Avatar
srchief100
Originally Posted by Red_Racer
Hey srcheif100...
The current avatar is the result of breeding.... Zilla and one of the Fem's in his avatar.. just never know what your gonna get
Old Nov 18, 2004 | 03:34 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
Check to see what your average mpg is on the DIC. I am pretty sure that the range works hand in hand with the average mpg. If it is low reset it
Old Nov 18, 2004 | 03:35 PM
NSTG8R's Avatar
NSTG8R
...breeding
Old Nov 18, 2004 | 03:38 PM
Zilla's Avatar
Zilla
Kick me when i am down, now that is not nice.
just because i am man pretty as you can tell from the picture below jealousy will get you no where
Old Nov 18, 2004 | 04:37 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
If your just sitting there, of course the range will go down. Running the car and not moving will result in 0 range, you are not driving.
Old Nov 18, 2004 | 04:44 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
true, but you are referring to "INST MPG" I think he is referring to the option just "Range" that is supposedly what's left in your tank total.
Old Nov 18, 2004 | 04:48 PM
SilverBullit02's Avatar
SilverBullit02
The range is controlled by the amount of fuel in the tank, the speed you are going, (and the distance you are covering) and the amount of fuel your engine is consuming at any given moment. If you're sitting still, in the garage with the engine running, you're using fuel and going nowhere. Your MPG is "0". It won't take long for your average to drop considerably. Hence...the range drops also. I've made the mistake of resetting my average MPG on trips while still accelerating on a freeway entrance ramp....range is very low. One time I got a "low fuel" warning with a full tank just by resetting at the gas station then accelerating very hard onto the freeway. Reset your average after you get to cruising speed.
Old Nov 18, 2004 | 04:50 PM
screw991le's Avatar
screw991le
No, if you are not moving and the car is running the range will go down, and sit there long enough and you'll run out of gas, not going anywhere the range will say 0 because you are now out of gas.
Old Nov 18, 2004 | 04:59 PM
WWK888's Avatar
WWK888
Well thats strange because in almost 3 years of ownership it has never done that. Every time I fill up I reset my trip, average speed and mpg and my range always resets itself at around 278. It does not drop as I sit there.
I just got back from a drive and it is still whacked, erractic readings. I will drive it for a while and refill the tank and see what happens.
Old Nov 18, 2004 | 05:06 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
gee ya think so?
Old Nov 18, 2004 | 05:41 PM
I agree, try resetting the average MPG and see if it goes back to normal.
Old Nov 18, 2004 | 07:39 PM
screw991le's Avatar
screw991le
gee ya think so?
I was being scarcastic, I have had 3 GM cars with DIC and they ALL go down if you just sit there.
Old Nov 18, 2004 | 11:42 PM
utrico's Avatar
utrico
I was driving yesterday to all of the sudden find a check gauge light on. I looked at the DIC and it said "Low Fuel." I thought this was werid for two reasons, it normally says reserve fuel and I filled up the day prior. Then I look at my fuel gauge and it is at 0! I pull over at first thinking I had a massive fuel leak. Then I remembered these cars have a mind of their own, so I turned it off and back and on and presto, everything has been fine since. I am just worried this type of stuff will happen more frequently as the cars get older. Has that happened to any of you guys?
Old Nov 18, 2004 | 11:48 PM
WWK888's Avatar
WWK888
You are experiencing a very common problem, the fuel sending unit is failing. You can try a different brand of gas or add some techron additive to see if that makes a difference.
To DIC-Fuel Range problem
Old Nov 19, 2004 | 12:36 AM
vetteship's Avatar
vetteship
I would suggest checking your DIC for codes (press and hold the option button and press fuel button 4 times with key on but engine not running), if fuel codes are set, try replacing the fuel sending unit, I did and all is well for now.
Old Nov 26, 2004 | 04:07 PM
vetteship's Avatar
vetteship
I have the same problem, no codes are set either, some CF members tried Chevron fuel injector cleaner or better yet "Red Line" injector cleaner and it cured the erratic DIC reading, I'm trying chevron first then Red Line, hopping it will work. I'll keep you posted.
Old Nov 26, 2004 | 04:12 PM
WWK888's Avatar
WWK888
Thanks...I am going to drive some more to use up more fuel then try the techron. My gas gauge is still working properly, just my "range" is whacked.
