Pump gas while car is running?
Old Nov 20, 2004 | 11:01 AM
mowton's Avatar
mowton
Originally Posted by speedy-vet
I've seen people do this couple of times but I've never done this with either car. An engine running while I pump gas or talk on cell?. The idea scares me!!
Am I wrong? is that safe?
Myth Busters proofed the Cell Phone theory is bogus. The better reason not to do it is todays computers and Check Engine lights illuminating because of improperly closed gas caps. Other than that, you are burning the gas as you are filling it!
Best I can comeup with. Good luck on your decision!
Guess I should read all the responses first. Sorry for the repeat!!!!!
Old Nov 20, 2004 | 11:15 AM
Pug's Avatar
Pug
St. Jude Donor '08
Originally Posted by madeouttaglass
I like the smokers at the gas station. Darwin awards?
While I would never leave the car running, or smoke while pumping gas I found it interesting when our safety committee at work took a clear plastic water bottle and added a few mil of gas and coated the entire bottle inside with it then dropped a lit cig into it and nothing happened.
something about a lit cig only burns at 850 deg. and thats not high enough to ignite gas fumes.
Then they took a simple little piezo spark device and set it off obove the bottle and it went off like a rocket. (static elec. sparks are around 1700 deg.)
The whole point of the exercise was to show how dangerous it was NOT to ground yourself out before pumping gas as when you get out in dry air the scooting across the seat would pump you full of static.
Old Nov 20, 2004 | 11:29 AM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
My Ferrari at the gas pump.....radiant heat from the exhaust and a little overspill and viola!!!!
Old Nov 20, 2004 | 11:30 AM
sweetcharity
Old Nov 20, 2004 | 11:55 AM
corvettebob1's Avatar
corvettebob1
Originally Posted by screw991le
The gas itself won't ignite, the vapors will. Get enough concentration of vapors and you'll get a flash fire. But out doors, I highly doubt it. But these is always a first time for everything. Am I the only one who paid attention in chemistry class? LOL
Guess they forgot to tell you the vapors are heavy and sink to the ground almost immediately, and your cats run at about 1200 deg.
I owned a service station for 12 years and saw several cars burst into flames at the pumps while the engines were running.
DO YOU FEEL LUCKY?
Old Nov 21, 2004 | 03:05 AM
speedy-vet's Avatar
speedy-vet
St. Jude Donor '06-'07-'08
Believe me, decision not needed before this thread, just getting opinions
After all these great responses It's just a matter of 'common sense'.
Thanks guys!
Old Nov 21, 2004 | 03:46 AM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
Originally Posted by 2k2C5
Not a good idea to pump gas with the engine running.
Talking on a cell phone at the pump is an urban legend. Mythbusters put that rumor to rest on their show and found that there is no danger at all.
I worked for several years at the mfg location of one of the major wireless makers and frankly the Mythbusters got that one wrong. According to all of the electrical engineers & the folks that actually mfg the printed circuit boards talking on a cell phone....placing a call.... turning the phone on......... can indeed result in kaBOOM.
Old Nov 21, 2004 | 04:44 AM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
boom.
Old Nov 21, 2004 | 04:50 AM
kumar75150's Avatar
kumar75150
thats all i needed to hear
I dont have cats so I guess I can do it.
Old Nov 21, 2004 | 07:06 AM
SlideRulz's Avatar
SlideRulz
Old Nov 21, 2004 | 12:58 PM
MiamiDave's Avatar
MiamiDave
Again, way more concerned about a static shock-which will ignite gas vapors-than hot cats, etc... With the new environment-friendly pumps which contain most of the gas vapor, I think there is even less risk than before.
I think there is a higher chance of winning the lottery and running out if front of your house going "..WhoHOO!..." and getting struck by lightning in a snow storm
Old Nov 21, 2004 | 01:05 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
In my talon tsi, the turbo timer lasts a minute anyways, so i ususally just leave it running. But any other car i always turn off.
Old Nov 21, 2004 | 01:14 PM
  #33
csexton's Avatar
csexton
I always shut mine down. Just don't want to be in that big of a hurry!!
Old Nov 21, 2004 | 02:22 PM
  #34
Loco Vette's Avatar
Loco Vette
From: Loaded like a freight train, flyin' like an aeroplane!
CI 2-3-4-5-6-7-8-9-10-11 Vet
CI X-XI Blind Cart Auto-X Champ
CI VI Autocross Champ
CI VIII Autocross Champ
CI VIII Cone-killin' champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10
Originally Posted by RedWolf
Nothing will probably ever happen but why risk it? Would hate to see my baby in a melted pile.
Old Nov 21, 2004 | 02:47 PM
  #35
PaceThis's Avatar
PaceThis
I've seen reports showing actual cases with a cell phone causing a fire at gas pumps. Most, if not all, are due to the person talking on the phone re-entering the vehicle while the gas is being pumped. The static electricity caused by re-entering the vehicle (esp. w/ cloth seats) combined with the cell phone can be very deadly.
Old Nov 21, 2004 | 05:37 PM
  #36
2 LOW 4 YOU's Avatar
2 LOW 4 YOU
Thats like driving with the cap off. air can get into the tank and set the computer off. Thats why u have to click most cars a few times
Old Nov 21, 2004 | 05:46 PM
  #37
gmosley's Avatar
gmosley
Default gas
i personally leave mine running while i pump gas
do it with all my vehichles never had a problem
To Pump gas while car is running?
Old Nov 21, 2004 | 05:47 PM
  #38
johnnyvettes's Avatar
johnnyvettes
CHICAGO CREW !
From: We are living in a Bazzaro World everything is upside down half ass backwards !
CI 4-5-6-7-8-9 Veteran
St. Jude Donor '06-'07-'08 & '12
my car doe's not shoot out sparks or flames when it runs ! so where is the danger if nascar can refuel there 800 hp race cars when they are running i can't see why i can't refuel my car J.M.H.O.
Old Nov 21, 2004 | 05:49 PM
  #39
yelloyello's Avatar
yelloyello
CI 6-7, 9-10 Veteran
I wouldn't pump it while it was running. But as far as talking on your cell phone. That was covered on Myth Busters. Nothing will happen if you talk on your cell phone. You need a spark to ignite a fire. Cell phones should not spark
Old Nov 21, 2004 | 06:26 PM
  #40
NSTG8R's Avatar
NSTG8R
Originally Posted by BBates
I used to do this with my old '69 Camaro. I did it because my starter got heat soak so bad that it often would not start the car back up. The headers were too close to the starter and not ceramic coated. I fixed that problem by getting rid of the Camaro and buying my current C5 Vette. Best decision I ever made!!!
... or you could have painted your starter white and kept the classic.
Keeping the car on is a very bad idea, almost as bad as using your cell phone while you pump. (edit: Screw Myth Busters, they're payed off!)
"If NASCAR can why can't I" ...
In what way does your car and the fuel compare to that of a NASCAR race car!? Also they're not endangering thousands of people because they use fuel jugs, instead of straight from a giant 500 gallon tank.
How hard is it to understand all you need is one spark.
Oh wait! Gas isn't that flammable. I dont know what everybody's worried about.
