Pump gas while car is running?
Old Nov 19, 2004 | 10:49 PM
speedy-vet's Avatar
speedy-vet
St. Jude Donor '06-'07-'08
Default Pump gas while car is running?
I've seen people do this couple of times but I've never done this with either car. An engine running while I pump gas or talk on cell?. The idea scares me!!
Am I wrong? is that safe?
Old Nov 19, 2004 | 10:53 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Whats the worst thing that could happen.. blow up..
I usually do leave it running..
Old Nov 19, 2004 | 10:54 PM
LoneStarFRC's Avatar
LoneStarFRC
Ungood
Old Nov 19, 2004 | 10:56 PM
BT-01-vette's Avatar
BT-01-vette
Here in NJ it's law to shut dn Syl
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
I like the smokers at the gas station. Darwin awards?
Old Nov 19, 2004 | 11:12 PM
speedy-vet's Avatar
speedy-vet
Ok, then I'll be prepared to blow up! Oh wait... I think not!
NJ= Is the law. Ok then perhaps we are spoiled?
Old Nov 19, 2004 | 11:14 PM
Scares me too. I shut mine off.
Old Nov 19, 2004 | 11:22 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Its cool if you want to blow up the whole freakin block
Old Nov 19, 2004 | 11:46 PM
RedWolf's Avatar
RedWolf
CI 6-7-8-9-10 Veteran
Nothing will probably ever happen but why risk it? Would hate to see my baby in a melted pile.
Old Nov 19, 2004 | 11:47 PM
BBates's Avatar
BBates
I used to do this with my old '69 Camaro. I did it because my starter got heat soak so bad that it often would not start the car back up. The headers were too close to the starter and not ceramic coated. I fixed that problem by getting rid of the Camaro and buying my current C5 Vette. Best decision I ever made!!!
Old Nov 19, 2004 | 11:55 PM
Dave68's Avatar
Dave68
Originally Posted by BBates
I used to do this with my old '69 Camaro. I did it because my started got heat soak so bad that it often would not start back up. The headers were too close to the started and not ceramic coated. I fixed that problem by getting rid of the Camaro and buying my current C5 Vette. Best decision I ever made!!!
Ha! I had the same problem with my old 68, only I solved the problem by buying a mini hi-torque starter and insulation blanket. Still, when I DID fuel-up without shutting the engine down, quite a few people looked veeeeery nervous!
Old Nov 19, 2004 | 11:56 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I believe the manual says to not remove the cap for the fuel tank with the engine running. The loss of pressure could throw a code.....
Why not just be safe and shut 'er down?
Old Nov 20, 2004 | 06:49 AM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
Not a good idea to pump gas with the engine running.
Talking on a cell phone at the pump is an urban legend. Mythbusters put that rumor to rest on their show and found that there is no danger at all.
Old Nov 20, 2004 | 08:01 AM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
I try not to do it but my truck has a 44 gallon tank and the pumps now a days are slow.IT takes a while and I almost always run it close to empty
Old Nov 20, 2004 | 08:12 AM
CAJUNY2KC5's Avatar
CAJUNY2KC5
I don't think it's a good idea at all. If you want to blow yourself up, go somewhere else to do it and leave the other people at the pumps alone.
And besides, as was mentioned - you can throw a code doing that anyway.
Old Nov 20, 2004 | 08:13 AM
MiamiDave's Avatar
MiamiDave
Why...?
I pump gas constantly while the engine's running, more or less for my whole life whether in the North b/c it's cold or hear cause it's so F@#ing hot. Especially since I usually get gas near my house when the 'vette's in warmup stage-and we all know how bad short trips are for unburned gas/sludge/etc.
And as far as a law in New Jersey, it's also against the law to pump your own gas-so it also makes sense that you shut your car off-one to insure you don't leave with the pump still attached (since you wouldn't know the difference), and two for the safety of the attendent.
The only thing you really DO need to worry about is static electricity on your person near the nozzle-and of course smoking
Old Nov 20, 2004 | 09:58 AM
WhiteC5Vette's Avatar
WhiteC5Vette
St. Jude Contributor
I would bet, if everyone looks at the caution signs at their nearest pump, it is against the law to have the motor running in all (or the majority) of states. Whether or not the person behind the counter knows that or not, is another question.
To Pump gas while car is running?
Old Nov 20, 2004 | 10:00 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
The gas itself won't ignite, the vapors will. Get enough concentration of vapors and you'll get a flash fire. But out doors, I highly doubt it. But these is always a first time for everything. Am I the only one who paid attention in chemistry class? LOL
Old Nov 20, 2004 | 10:05 AM
jrose7004's Avatar
jrose7004
I would never pump gas into a running car!
Old Nov 20, 2004 | 10:44 AM
Blue Lion's Avatar
Blue Lion
I always turn the car off and stay off the cell phone, just to be safe.
