Back window FELL OUT!!!!!!!
Old Nov 20, 2004 | 10:14 AM
oyealiz's Avatar
oyealiz
2022 C8 of the Year Finalist - Unmodified
CI 3-4-5-6-7-8-9-10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'16
Default Back window FELL OUT!!!!!!!
While the Pace was being dried off yesteray at the detailing shop, the back window literally just fell into the car. I know I have read a few times here about this happening.
Is there ANY fix besides replacing the top?
Old Nov 20, 2004 | 10:17 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Replacing the top is the only thing to do. I am sure that someday the same thing is going to happen to my 99 convertible as well.
VR
Old Nov 20, 2004 | 10:36 AM
TRAYC7's Avatar
TRAYC7
NCM Ambassador
CI-3-4, 9 & 10 Car Show Winner
CI-3-4-5-6-7-8-9-10 Veteran
St. Jude Donor '04-'05-'06-'07-'08-'09-'10,'14, '16
St Jude Fedex Bowl Donor '09
Dang that is unreal... I dont think I have heard of that happening... I know on my 89 C4 vert the window was the plastic instead of the glass.. I had to have it replaced and restitched within the existing top... had a place here in Lexington do it....so I didnt have to replace the entire top... just a new window... I can give ya the info if you want it....
Old Nov 20, 2004 | 11:01 AM
MilYellow02's Avatar
MilYellow02
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Just damn, Sorry honey!
Old Nov 20, 2004 | 11:19 AM
Topless's Avatar
Topless
Cruise-In IV Veteran
If I remember right, the window is bonded to the top. I don't know if an upholstery shop could fix it or not. It's worth asking one though.
If you can find somebody in the club that has had their top replaced and the shop did a good job, those would be the people to call.
Old Nov 20, 2004 | 11:36 AM
white top's Avatar
white top
Someone on the forum dont remember who said he fixed his using silicone caulk of some kind. Do a search you might come up with something.
Jerry
Old Nov 20, 2004 | 11:53 AM
gtzy's Avatar
gtzy
I have successfully bonded a 20 in seperation of the top/rear glass at the lower portion. Since the majority of the glass was still in place,holding and aligning the glass was not an issue.
With total seperation you may be able to clamp the glass in position and bond the perimeter in sections. A glass shop may be able to handle this using urethane glass bonding agent.
Since a new top will prob run $1000 installed,,nothin to lose trying to repair it.
Old Nov 20, 2004 | 12:23 PM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
St. Jude Contributor
Damn Liz...that's awful I hope there is a cheaper way to do it than replacing the entire top, but that might be the best fix.
Good luck!
Old Nov 20, 2004 | 12:36 PM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
I had happened on mine as well ...
You will need to replace the whole top.
Good luck!
-Mike
Old Nov 20, 2004 | 12:47 PM
onebadvette03's Avatar
onebadvette03
Damn, thats a new one to me. Sorry to hear about that Liz, hope you get it fixed ok.
Old Nov 20, 2004 | 12:55 PM
iceburgh's Avatar
iceburgh
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05-'06-'07-'10
I have seen this on many verts.
A guy in our club had this happen ...he went back to the dealer and they had a interior person glue it in...that was 3 years ago and no problems. Not sure what they used but the top had to come off and was put in some type of heat press with glue
Old Nov 20, 2004 | 01:29 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Much better than buying new. Keep us posted. I am sure this will become an issue for more of us.
Old Nov 20, 2004 | 02:55 PM
Violater's Avatar
Violater
Cruise-In- II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
St. Jude Donor '06
it can be epoxied back in
Old Nov 20, 2004 | 02:57 PM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
Liz, Tracy, and Joe in C5 general? I had to look at the calendar to see if it wasn't 2003.
Old Nov 20, 2004 | 03:12 PM
PaceThis's Avatar
PaceThis
If it's all the way out, I'd suggest a top replacement. You might contact Slamndvert to see if he has any. I just sold one from an 02 vert (black) on eBay for $350 in excellent condition. I took it off the frame myself and took pictures along the way. Now, I have to reinstall the shale top onto the new frame...doesn't look like it'll be that hard, though I have to go pick up a different staple gun as the one I have isn't powerful enough for upholstery work. It took me about 2 hours to uninstall the old one. I think it will take me 2-4 hours to reinstall the new one...just to make sure it's adjusted tight. These times are with the top frame off the car...I think it might be easier if the frame is mounted on the car...
On rebonding it, I had a friend successfully reglue a portion of his, but I wouldn't recommend it for the whole rear glass. ON top of that, your car is now 7 years old and the time required to do the bonding might be wasted if your top needs replaced in the next year or two anyway. Once they start to degrade, they' typically go pretty fast. If the car has not always been garaged, the UV will have already taken a pretty good toll on it...
Best of luck in getting her fixed!
Old Nov 20, 2004 | 03:53 PM
oyealiz's Avatar
oyealiz
my fan club follows me.
onebadvette03.............tell teresa to quit looking so frickin hot in MY thread.
iceburgh and violater.........i hope yall are correct on the glue thing working!!! i will call around monday to see who is willing to try doing this for me.
Old Nov 20, 2004 | 03:56 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Don't feel so bad you are now the founding member of the FHC
F lying
H atch
C lub
Just kidding, that sucks
To Back window FELL OUT!!!!!!!
Old Nov 20, 2004 | 04:03 PM
I think I would see if a shop could bond it back in first. If not, you really have not lost much. You can always replace the entire top if that doesn't work. Best of luck. Sorry to hear that his happened.
Old Nov 20, 2004 | 09:23 PM
gtzy's Avatar
gtzy
When this happens,you can only hope the glass breaks, then becomes an insurance claim covered under comp
Old Nov 20, 2004 | 09:37 PM
IllinoisCorvette's Avatar
IllinoisCorvette
This can be fixed by a trim shop no problem.
