Need some ideas on weight saving...
[1] Aftermarket wheels probably weigh more than magnesiums
[2] Divorce is eminent, but adds horspower
[3] This is going to be harder than I thought
All joking aside, this is great info, thx all for contributing.
So far I'm at 170 lbs, but you're left with a track-only car, so you might as well keep going and...
Get a plastic windshield, cf body panels, cf driveshaft, newer torque tube, 2-piece front brake rotors, or Ti rotors, no cats, delete the windshield wiper system, remove all carpeting and insulation, remove door side-impact protection bar, remove airbag sensors, cf seats, Ti or Al fasteners, cf steering wheel, remove rear speakers and all radio wiring, remove all lightbulbs and wiring, aftermarket shifter with Ti ****, remove headlight motor and hardware, remove foglights, coil-over suspension with Ti springs, Ti lugnuts and Hoosiers. As for the engine, Ti or Al connecting rods, Ti valves, Ti valve spring retainers, Ti pushrods, magnesium or cf valvecovers and aluminum pulleys.
Do all this, and you'll lose hundreds of pounds. Now you're left with a hardcore track-only car. If you went all out, I'd guess you'd be damn close to 2,000 lbs. Add a hundred or so pounds for a rollcage, harness, bigger radiator/oil-cooler combo and Accusump.
If you're building a drag car, you could also put skinnies on the front, remove the ABS system, remove power steering, remove AH/TC sensors and remove front (and rear??) sway bar.
NJblackrose92, you asked if this would change your suspension dynamics. This is a no brainer, but yes, removing over 1,000 lbs from any car will change the suspension dynamics. At the very least, if the spring rates aren't changed, the car will look like a 4x4, and shocks will have to be tuned accordingly. If all these mods are done, the polar moment of inertia will be much less, the center of gravity will be lower, and there will be MUCH less rotating and unsprung weight. I can't even imagine what driving a Vette like this would be like, but I'd love to find out!
**EDIT** Sorry, just noticed you already got the magnesiums
IMO, you would be better off modding the car for more HP and swap out old parts with lighter pieces that provide more HP. A C5 in stock form runs a ratio of 9.28 lbs per 1 HP... after all my mods I am at 4.39 lbs per 1 HP... even with the car picking up 180 lbs from a S/C and Roll Bar.
VR
but ON OR IN THE car
Remove stock seats and put in racing seats. Save over 50 pounds.
remove speakers ( 5lbs each I bet)
take out the airconditioner core and the ac unit.
Carbon fiber body pannels - 10 lbs savings on the hood alone
Wheels - get rid of the GM wheels or knock offs. OZ and BBS have magnesium racing wheels but at $10 Large a set, OK maybe not.
But CCW wheels will save you some weight.
Run flats are very heavy tires go with DOT R compounds.
Lexon windows - save over 50% of the weight of glass and safer too.
http://www.melroset-tops.com/lexan_windows.htm
There are a few Ideas.
Taking out the radio, AC, carpet will give you a really unpleasant car. In the end you shaved off, 30 lbs, and on a 3150 lb. car, thats barely 10%.
Add more HP, it's easier and a lot more fun.
Maybe slimfast!!!
