Is there a way to change the default setting on 04 Blose system. I seem to have to always toggle to get it to a particular setting. I listen to Bluesville and I find that the "jazz" setting sounds best. However, unless I remember to check, when the motor starts up, it defaults to a setting I don't like. What settings do you prefer? Also, what is the Alpine model number that replaces the back speakers? Thank you very much.
Try setting everything up the way that you want it and then pressing your memory button and holding it down until the light flashes. It should store all of the radio seat mirror and AC settings. When you unlock the car with the FOB everything should be just like you like it!
no, I wasn't trying to correct you. I have no idea what you're talking about. I'm thinking and I've got a terrble and a bass ****, where is there an equalizer?
The button says "autotone" and is right above the clock setting buttons. That allows you to toggle through the pre-set settings, such as country, rock, jazz, classical, news... Thanks
BC
I have tried that since day 1 and it still doesn't work.
