Shiftknob on A4 loose???
Old Nov 26, 2004 | 12:58 AM
Vette '01's Avatar
Vette '01
Default Shiftknob on A4 loose???
Does anybody know how to fix a loose shiftknob on a 2001 auto trans?
It just kinda bugs me
Old Nov 26, 2004 | 01:02 AM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Is you horseshoe shape pin still in the shifter ****?
if so try taking some of the thread tape that you use on plumbing fixture to stop leaks, that should allow you to build up the diameter of the shaft for the shifter **** so that it will be a little tighter. it's worth a try
Old Nov 26, 2004 | 01:13 AM
Vette '01's Avatar
Vette '01
Tks for the info zilla
Now how do i take the shiftknob off?
Old Nov 26, 2004 | 01:33 AM
98SilverVette's Avatar
98SilverVette
wondering how to fix this as well
Old Nov 26, 2004 | 01:39 AM
Dave68's Avatar
Dave68
I know for a fact that Grumpy has replaced his auto shift ****. You might want to IM him.
Old Nov 26, 2004 | 01:52 AM
IMQUIK's Avatar
IMQUIK
Pull out horseshoe pin (I think it is on the front side) with needle nose pliers & pull up on your ****. the shifter ****
Old Nov 26, 2004 | 10:19 AM
WhiteC5Vette's Avatar
WhiteC5Vette
St. Jude Contributor
Old Nov 26, 2004 | 10:20 AM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
the picture above says it all.... real easy to do, if I can do it...
Old Nov 26, 2004 | 11:34 AM
Zilla's Avatar
Zilla
A very small screw driver would help also just to get the horseshoe pin started. and no wonder I was have trouble removing mine because i was pulling the wrong ****
To Shiftknob on A4 loose???
