One of the spring steel straps that seals the filter into my OEM airbox is either not attached at the bottom or broken. I can't see down there and can't reach anything from below. It can be pulled up and has a bent area on it at the bottom. Is there a way to re-install it without taking the airbox out? TIA.
No, but taking the airbox out is simple. Just loosen the hose clamp that attach the airbox to the MAF sensor, lift the snorkel slightly, and pull the MAF sensor away from the airbox. You can then just pull the airbox out. It is only being held in place by 2 studs on the front of the car. Should take about 5 minutes to get it out.
I agree, removing the stock airbox is a pretty easy job. Once you get the clamps loose (you choose the location, MAF or airbridge coupling) the most difficult part is getting the airbridge off of the pins. You'll see where they are when you get started. They are nothing but rubber bushings pressed over a plastic "pin". Just take a towel or shop rag and cover a large screwdriver and use this to pry them straight up and off the pins. The airbox is held to the front of the radiator with the same type of pins.
Here is a tech tip for a Blackwing air filter install. It contains some pretty good pictures to help illustrate what I'm talking about.
Once you get over the fear of removing the entire air box assembly, you will kick your self in the A$$ for not doing it earlier!
I spent hours doing the same repair as you. Once the entire air box assembly was out, it was fixed in 3 min!
Remove the MAF wireing harness, remove the air pump inlet hose remove the clamp from the throttle body, Pop it off the two studs on the front frame header and pull the entire assembly out. Its that simple! While it is out throw in a K&N or Air Hog filter!
The pins holding the MAF sensor to the air bridge are easy to remove. Just use a small screwdriver, pry up the pin inside the rubber grommet, and remove. Then pull the MAF/Air bridge assembly upward and off the radiator support. This is after you have remove the clamp on the bridge to the throttle body, and disconnected the MAF sensor connector, and don't forget the air pump hose on the left (driver side).
Then from the front of the car, push rearward on the bottom of the air housing assembly to push the assembly off the two lower pins.
The straps are bent at the bottom to connect over a bottom lip of the housing. My straps kept popping off, so I pulled the assembly off, then wrapped two large (one for each side) black tie straps over the straps once they were back in place. This prevented the straps from ever coming loose again.
When reinstalling, I suggest using some lube on those two bottom pins to allow the assembly to slide on, and off in the future.
I just remove the hole damn thing from the throttle body to the air box! Much easier! That way I can inspect the entire assembly and make sure that all of the connections are tight and leak free!
I also put off taking the airbox off when my straps came loose. I bet your strap will fit again and is not broken. You'll find out when you remove the box. You can do it!
Thanks to all for the tips. You have given me the confidence to do this. May just have to get that Blackwing. "Dear, the experts said I need to get a Blackwing. How about for a Christmas present?" Sounds good...I'll try it.
Good idea Just let her ask us, we'll back you up. Blackwing owner here and very happy with it.
