DIC question
Old Nov 26, 2004 | 02:56 AM
mlumb's Avatar
mlumb
Default DIC question
my car is often stood for 4 or 5 days during the week,the last two times ive got in after this the DIC has moved to different settings than i usually have.
it goes to the same 'base' settings each time,also changes the page on my HUD.
i wondered if the battery is on its way out although radio and other memory functions seem ok.
battery volts when driving are 13.8/9
what do you think?
mike.
Old Nov 26, 2004 | 03:05 AM
Ag_bullet's Avatar
Ag_bullet
Sounds like a battery issue.
Mine did the same thing. DIC and HUD settings different than I left them. New battery solved the problem.
Old Nov 26, 2004 | 05:24 AM
ooh yeah's Avatar
ooh yeah
Do you have teenagers in the home??? Maybe they are taking the car out after Dad goes to bed.
Old Nov 26, 2004 | 07:25 AM
Thunder7's Avatar
Thunder7
This is where I would start as well, sounds like a slow drain on the battery to me. Mine cranked OK and no problems, then overnight I had weird DIC issues, then within a day or two no crank power at all. Replaced battery, and all has been good since.
Old Nov 26, 2004 | 07:48 AM
Have the battery checked.
Old Nov 26, 2004 | 09:40 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Battery is going low at initial start up and the memory module takes a hit and resets. Check the codes and see if you have any LOSS OF COMMUNICATION" codes. Sure sign of a bad battery!
BC
Old Nov 26, 2004 | 10:37 AM
mowton's Avatar
mowton
what do you think?
mike.
S/B more like 14.3. I agree with the weak battery theory
Old Nov 26, 2004 | 02:33 PM
mlumb's Avatar
mlumb
battery down to about 11v on starting,ive never looked before so dont know what it should be,ill get it checked.
mike.
To DIC question
